Vue F.A.Q (Last Updated: 2024 Sep 20 5:40 am)
You want to export a Poser figure? I don't see why you want to do this, since you can export a Poser figure from inside Poser in 3ds, obj, etc.
Inside Vue, you can only export Vue objects, items that are in a Vue format, terrains, objects in the vob formats, plants in the veg format, etc...
Now some vob objects cannot be exported, because the maker of the object locked it from export. So it can only be used inside Vue. This is applied to some of the stock objects, and objects you buy at Cornucopia. At Corn, it is clearly stated in the object description if locked or not.
The reason i wanted to do this was i wanted to try to render this figure in 3dmax just to see the differences between pose,vue and 3dmax render , but any file format ive tried to export from poser dosnt seem to want to open in 3dmax so thats when i thought may be i could export from vue instead and the found i couldnt hope that explains what seems like an odd thing to do
3DS MAX should import .obj files exported from Poser without too many problems. You'd have to do some work on the textures though
My Freebies
Buy stuff on RedBubble
Quote - ... but exporting from Poser as a 3ds file should work, you may get into problems with finding the textures, due to some limitations in the 3ds format ...
The biggest drawback to exporting to 3DS format from Poser is that there is a polygon limit (64K polys) that all but the really old figures exceed (and that's just one figure let alone a whole scene).
a figure that i imported into vue from poser pro to vue7 xstream and then rendered ok with a new back ground will not let me export it iget the errror messsage "sory the selected objects have been locked from export.They cannot be exported. Any one able to tell me whats going on here and can i unlock them . It appears only the poser object is locked the background i can export any help much appreciated
