Thu, Feb 13, 6:14 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 13 3:49 pm)
Subject: posing multiple obj's
papillon68 ( ) posted Fri, 24 April 2009 at 11:47 AM · edited Thu, 13 February 2025 at 6:05 PM
I'm very new to Poser so forgive me if this is a basic question.
I have a model composed of several parts (body, eyes, teeth etc.).
Each part is a separate .obj file, so in Poser I'd like to import those files, and later pose those.
But I'd like of course that if I create bones on the body and I pose it, that eyes, teeth etc. would pose accordingly.
Is that possible or I have to merge all the body parts into a single mesh and then pose it ?
visit my blog:  www.alessandromastronardi.com
My Rendo Store
markschum ( ) posted Fri, 24 April 2009 at 1:11 PM
Import all the parts to poser. position them in place and parent the parts to the appropriate bodypart. Then open the hierarchy editor and check your figure. There is a button near the bottom to create a figure from your hierarchy.
nruddock ( ) posted Fri, 24 April 2009 at 1:33 PM
You really need to have all the parts in a single OBJ file, otherwise you'll have breaks at the joins.
There is no need to weld the parts, Poser does this internally for body parts.
lesbentley ( ) posted Fri, 24 April 2009 at 6:49 PM
Quote - You really need to have all the parts in a single OBJ file, otherwise you'll have breaks at the joins.
Welding still works even if the geometries are loaded by separate 'objFileGeom' statements, rather than a single 'figureResFile '. The important thing is that the vertices in one part match up exactly (or almost exactly) with the vertices in the other part.
lesbentley ( ) posted Fri, 24 April 2009 at 7:29 PM
file_429373.TXT
Attached above is the proof of the pudding. the file loads one box via 'objFileGeom', and the other geometry is 'geomCustom'. I could have used two 'objFileGeom', but then I would have had to distribute a separate obj file. Note that the two boxes in the figure are welded.
