Tue, Nov 26, 7:12 PM CST
Subject: finding imported objects textures etc
iborg64 ( ) posted Sun, 26 April 2009 at 8:34 AM · edited Fri, 22 November 2024 at 10:55 PM
As this is my first post I appologise in advance if this is in the wrong place first a bit of background to explain why i do things this way , i used to use poser 7 in xp and then later built a pc mainly for rendering and this had vista 64 bit on i found that poser 7 seemed to give me lots of problems in vista so i went on to buy poser pro and that was better but to save some trouble ( so i thought ) i just linked the poser 7 runtimes into poser pro. Every time i add new things I still put them in the poser 7 runtimes so they still appear in poser pro. I do a lot of my poser rendering in vue 7 xstream and either import the poser scene or poser object saved as an obj Now to the actual problem when i import the object in to vue ,vue cant find textures or jpgs and i have to look for them so first is there a place that I should save poser obj to so that vue finds all the bits its needs? or and this would be usefull for poser as well can I add my poser runtime to an indexed search in vista (and how do I do that) this would help for those few times when poser cant find bits and I need to search for them i wonder if this is a consequence of putting them in pose 7 runtime and then linking them in poser pro i have a buuton on my mouse that brings up vista search but defaults to only indexed files so i have to keep showing it where i want to search it would save me a lot of time if it would just default to poser runtime .thanks for any help from many one who followed that and has any advice.
AVANZ ( ) posted Sun, 26 April 2009 at 9:15 AM
In the preferences of Vue you can point to additional texture folders. Go to the "Operations" tab and point to your .../Poser/Textures/ folder.
The next time Vue can't find a texture it will suggest one from this folder. Click yes to all and you are done!
Cheers!
iborg64 ( ) posted Sun, 26 April 2009 at 9:17 AM
Thank you i will give that a try
Rutra ( ) posted Sun, 26 April 2009 at 4:48 PM
There are several old threads about PoserPro and Vue in this forum. If you make a search you might find some useful hints.
I did a quick search (not thorough) and I found these threads:
http://www.renderosity.com/mod/forumpro/showthread.php?message_id=3239123
http://www.renderosity.com/mod/forumpro/showthread.php?message_id=3366930
http://www.renderosity.com/mod/forumpro/showthread.php?message_id=3380082
Rutra ( ) posted Sun, 26 April 2009 at 4:52 PM
By the way, I also have Vista 64 bits (Home Premium) and Poser 7 and I never had any problems with this combination.
If you use Vue, I don't think there's many advantages in having PoserPro instead of Poser7. The main advantages of PoserPro are not very relevant for Vue users, from what I read.
iborg64 ( ) posted Sun, 26 April 2009 at 5:06 PM
poser 7 crashed quite a bit in vista but since using poser pro ive not had any problems so it does appear to be more stable , at least for me on my system, though to be fair to poser 7 it never gave me any trouble when run in xp.
MyCat ( ) posted Mon, 27 April 2009 at 6:23 AM
Wow, setting LIB_POPUP_TIMEOUT 0 really really speeds up start up! Like from a minute to 8 seconds! I never use that folder drop down menu anyway.
