Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 28 11:34 am)
There are two things to get right: the pixel dimensions (maximum 4000 x 4000) and the file size (maximum 512kBytes).
Assuming you have not done a huge render size, it's most likely that you are exceeding the file size. You can check the file size by looking at its Properties in your file browser - Windows Explorer on a PC.
If the file size is too big, you can either a) reduce the image size (in pixels); or b) increase the compression of the image by saving it as a JPG image at a reduced "quality" setting. Whichever you do, make sure to keep your original full size/quality render!
See if MS Digital Imaging will let you save your render as a JPG, and if so it should allow you to set image quality. Decrease image quality slightly to give a smaller file size, but don't go too far or it starts to look real bad with compression artifacts.
Hope it helps a little....
"If I were a shadow, I know I wouldn't like to be half of
what I should be."
Mr Otsuka, the old black tomcat in Kafka on the Shore (Haruki
Murakami)
Greetings and Salutations To All,
I am trying to upload a recent render. I am getting this message:The file you uploaded violates one or more of the following specifications for this gallery section: min 100 x 100 / max 4000 x 4000 @ 512 kilobytes. Please adjust your file size and try again
I don't know what this means. Obviously my render is too big. I know how to change image size using Microsoft Digital Imaging but I don't know how to get it inside the parameters required.
Any Help, Please
Thanks In Advance
Viper
R I P MJ. He's must have needed an Angel escort in Farrah
Please spay and neuter your pets. Strongly consider shelter adoption before spending $500 to $1000. If you MUST part with that kind of money for a pet, go to your local shelter, donate the money to them and pickup a highly adoptable pet. The shelters could sure use the donation.
