Sun, Feb 9, 3:24 AM CST
Subject: How do i stop this flickering in my animations
renderclipps ( ) posted Sun, 03 May 2009 at 10:34 AM · edited Tue, 04 February 2025 at 4:36 AM
I'm uploading 3 images from a sequence but there seems to be a shadow that flickers on the face of m3. Hopefully you can see from the pics below
renderclipps ( ) posted Sun, 03 May 2009 at 10:36 AM
renderclipps ( ) posted Sun, 03 May 2009 at 10:38 AM
hmmm it's quite hard to see what i'm talking about from these stills but his face does flicker
ice-boy ( ) posted Sun, 03 May 2009 at 12:48 PM
i see it. the shadows changes.
shadow map is to low.
Miss Nancy ( ) posted Sun, 03 May 2009 at 4:07 PM
can't see it, but this is a well-known problem.  set all lites to non-animating and post screencap of render/movie settings.
renderclipps ( ) posted Sun, 03 May 2009 at 4:19 PM
Quote - i see it. the shadows changes.
I presume you mean the..
Shadow blur radius 0.0
SHadow min bias    0.8
I'll try playing around with these
cheers
ice-boy ( ) posted Sun, 03 May 2009 at 4:28 PM · edited Sun, 03 May 2009 at 4:28 PM
shadow map. its above intensity
renderclipps ( ) posted Sun, 03 May 2009 at 4:30 PM
> Quote - can't see it, but this is a well-known problem.  set all lites to non-animating and post screencap of render/movie settings.
Thanks
I'm trying with the non animating lights now
renderclipps ( ) posted Sun, 03 May 2009 at 5:41 PM
OK THANKS THE SHADOW MAP WAS 256
SETTING TO 1024 ??
Thanks
renderclipps ( ) posted Sun, 03 May 2009 at 7:52 PM
hmmm
taking off the animated lights and increasing the map size to 1024 didn't work (map size was originally 256, gonna try again with 2048)
markschum ( ) posted Sun, 03 May 2009 at 9:20 PM
before you increase the size , select the shadowcam for the light and see how big an area it covers, you may want to zoom it in to cover only your render area.
renderclipps ( ) posted Mon, 04 May 2009 at 9:46 PM
Quote - before you increase the size , select the shadowcam for the light and see how big an area it covers, you may want to zoom it in to cover only your render area.
working now
big thanks
markschum ( ) posted Mon, 04 May 2009 at 10:16 PM
for animations you may find occasionally that antialiasing causes flicker.
shadow cams are a big thing to be aware of.  Now you are :)
