Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 19 4:00 pm)
Attached Link: http://market.renderosity.com/mod/bcs/index.php?ViewProduct=71068
Mec4D has a utility on her product pages that is a python script that allows a change to White, Medium Grey, and Grey :) Scroll all the way to the bottom to find the URL :)Sitemail | Freestuff | Craftythings | Youtube|
Knowledge is knowing a tomato is a fruit. Wisdom is not putting it
into a fruit salad.
What you want has been done in various python scripts . I have one at sharecg that sets the diffuse color to grey, it would be easy to amend it to either of your requests.
http://www.sharecg.com/v/23657/Script/Set-diffuse-gray-script-,-for-light-set
changing ONLY skin materials would simply require a filter , easy enough if the name contains the word skin.
Hi markschum,
I tried your script "setgraydiffuse.py" in P6 on Posette, but got the following error.
Figure 1
GROUND
UNIVERSE
FocusDistanceControl
Light 2
Traceback (most recent call last):
File "", line 30, in ?
AttributeError: 'NoneType' object has no attribute 'InputByInternalName'
Any ideas?
Cheers,
Les.
Works for me in Poser 7 , the same code is run for figures and then props
Its failing in the props section .
the prop name should have been written out to the display , theres something in that props materials that isnt what the script expects. It may be to root node name in the shader tree.
If that doesnt help I will give you a script to catch the error .
Hi All,
As a time saver I'd like to create some utility MAT poses for Poser 6/7, but I don't know where to start.
Basically I want to have a one-click pose to set the diffuse color for all of V4's shading zones to white while leaving any texture maps connected and intact. I'd also like to have a MAT pose to change the specular color to black on any "skin" material zones.
I've seen this done before, but I haven't used Poser in a long time so I'm kinda clueless :)
Any insight is deeply appreciated.
Thanks guys!
