Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 13 11:02 am)
I'm definatly not the best person to answer this question, as I don't have Mimic, but I felt sorry for this poor little thread with just one post sitting all lonly by itself.
To my understanding (which may be completely wrong) Mimic works on phoneme morphs in the head actor of the figure. If this is correct then to be compatible with Mimic, a figure would need to have phoneme morphs with the correct names. What I am guessing is that the morphs in M4 do not have the right names to work with Mimic.
If my guess is correct then I have an idea that may fix things. First I need to know if I have a figure that is Mimic compatible. Could you please list the ones that you know of that are Mimic compatible? If the P4 Nude Man and Woman are compatible, that would be excellent.
Attached Link: http://www.renderosity.com/mod/freestuff/index.php?user_id=51892
Little_Dragon made a mimic compatible V4 that's available in the freestuff here. Could you do a M4 version by seeing how the V4 one was done?Before I go to the trouble of reinventing the wheel. Try this experiment. Install Little_Dragon's "Victoria 4 Phonemes". Open the "Victoria 4 Base Phonemes.cr2" in a decent text editor, I use "EditPadLite", "WordPad" will do at a pinch. About 8 lines into the file, you will see a line that reads:
readScript :Runtime:Libraries:Character:DAZ People:Victoria 4 Base.cr2
Try changing this to read:
readScript :Runtime:Libraries:Character:DAZ People:Michael 4.cr2
Resave the file as "Michael 4 Phonemes.cr2". Then follow the instructions in Little_Dragon's "Victoria4Phonemes_Readme.txt" using "Michael 4 Phonemes.cr2" in place of "Victoria 4 Base Phonemes.cr2".
I think there is a good chance it might work. V4.2 and M4 are very similar, but I think Little_Dragon's file was made for V4, not V4.2, so it depends how much has changed in the meantime. Anyway, it's worth a try, and would save me a lot of work if it does the job.
Save the "M4Speak.pz2.TXT" to a pose folder, dropping the ".TXT" part of the file extension. Load M4, make sure all the visim morphs are injected into M4, only then apply the "M4Speak.pz2" pose. Save M4 back to a pallet with a new name, then do what ever it is that you do in Mimic. It may work it may not, I am not overly confident.
Is it possible to get mimic 3.1 to work with Michael 4.?
I have tried several different approaches to no avail. It loads Michael 4
and I get some head movement and thats about all. I tried saving Michael 4
with all the head morphs and loading that character in Mimic , and still
doesent work.. Any suggestions?
