Hi :-)
Vue7.4I Beta build 42554 here on PC. Same happens when the second layer is selected. At least, the first layer disappears from the view-windows. It's still there in the preview and when it's rendered. If I deselect the second layer, I see all objects, at least until I add objects in the second layer. I just loaded a tree in the second layer - it loaded outside the (unmoved) camera field... If I then toggle between the two layers, I only see the objects in the selected layer in the view windows. the preview shows everything. Was this the same in Vue6? Doesn't seem very friendly to setting up a scene - dunno - maybe lodge a ticket?
P.S. could you try to load dynamic hair in 7.4, please? I get crashes every time by loading, and up until now, nobody has answered my thread. Hmmmm..... am I the only one that would like to use Poser shaders????
Rob
*I don't have the beta update like TH - mine is 7.40-04 build 42554
*Afraid you do Gill [LOL], that is the Beta update and it's the same as mine also.
If you look at the first line, they put it there in small writing!!
**TH: ** Dynamic hair............Instant white screen of death!!
Injustice will be avenged.
Cofiwch Dryweryn.
Jeez, that's a bummer!!
That's one thing I'll never understand, it's basically the same kit with some functionality taken out so how can it not work right in one and not the other!!
I had this bother with Vue 5 Esprit, that was a total bag of shit. After some, shall we say discussions, they offerred me a deal on 5 Infinite which was way, way better than Esprit, I never could figure why!!
Cofiwch Dryweryn.
Let's forget dynamic hair. E-on has replyd to me that they've fixed the crash, but Poser and Vue have different render engines. Because Poser has a scanline renderer, it can interpret dynamic hair. Vue has a different render engine. Therefore we cannot expect realistic results. OK, if that's the way it is,..... why did e-on say that they can import Poser dynamic hair?
Before I rant off at Vue I need to check if anyone else is getting this or if it's a tick box I need to tick or untick!
Start off with 1 layer, add a few things then click on new layer.
Now I have 2 layers, if I select the object in the new layer, my first layer disappears!!!???
Now having the first layer vanish like this isn't good for posing my item in the second layer is it!!
Any ideas anyone?? or is it another bug?
By the way, it makes no difference whether the first layer is open [eye], locked or sleeping! [closed eye], it still vanishes!
Cofiwch Dryweryn.
