Forum Moderators: Lobo3433
3D Modeling F.A.Q (Last Updated: 2024 Nov 10 9:34 pm)
Blender | Trimble Sketchup | Wings 3D | Anim8or | Metasequoia | Clara IO (Browser-based 3d modeler)
Check out the MarketPlace Wishing Well, as a content creator's resource for your next project.
The total number of vertices and polygon count will effect the program but scale doesnt matter.
The amount of detail that will show would depend on your resolution . That is if you adjust the camera to show the entire building and do a pic say 320 x 240 you will see less detail than in a pic 3200 x 2400 and that is regardless of the model scale.
Note here: the model coordinates for a vertex may be 7 decimal places. If your scale is very small you may get into issues about the number of decimal points available to fit a new vertex between two others.
Thanks for all the help.
But I can't think of another solution for my problem other than to be a bit less realistic in my model I guess.
I am making a promo-movie for a new to be built eco-holiday house and we want to show both overviews and details. Perhaps I went about it the wrong way and I better make multiple models (big, less detailed ones for the overview, and small, detailed ones for the zoom-shots)
That would probably make more sense anyway.
What modeller are you using? If it's a subdivision modeller you could export different levels of detail depending on the shots required. Otherwise, having several models may be the only way to get around the problem. You could cut up your high-poly model to use for close-ups, and make a low-poly version for distance shots.
You could also think about using displacement maps to add detail rather than polygons. There are plenty of options.
Attached Link: http://wiki.blender.org/index.php/Doc:Manual/Modelling/Meshes/Subdivision_Surfaces
I don't think Sketchup does subdivision, but Blender does, and the Blender forum here is a good point to start asking for advice on how to do it. I still haven't started on my "Blender for Dummies" book, so don't ask me. :) Here's a link to the Blender wiki on subdivision.This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
I am currently designing a building and sofar I am modelling it 1:1. The problem is that the model is growing and as such the program becomes slow (Vue) to respond. I was wondering if modelling on a smaller scale (1:10) would affect the response time, and if it would decrease the level of detail in the final render?
