Vue F.A.Q (Last Updated: 2024 Sep 20 5:40 am)
I haven't tried saving plants 'veg' files, but I've got exactly the same problem with the supplied 'Meta Cloud' previews. I think you'll find that it's a known issue and that it will be fixed in the next patch; at least I hope it will. :-)
Adriaan Barel (a.k.a. Vege
Mite)
"Morality, like art, means drawing a line someplace." --
Oscar Wilde
I did as you said and when I started Vue it told me that my version was an upgrade and that I would have to locate the installation of the previous version for my content to work in the current version. Rather than mess around and start from scratch, I put the Vue 7 Infinite folder back as it was before.
Mite)
Oscar Wilde
They're in a slightly different place on Vista but I found them.
I deleted the .prv relevant to the trees I'd just saved but the new preview generated was exactly the same. I did it again and the 3rd tree preview had changed. The top half was the same as tree #2, the bottom half was the same.
But, if it's a known bug then that's ok as long as they fix it PDQ
Gill
Hi -
I installed the "official" 7.4 (Complete) update today, and the previews are back! Both the clouds and the custom veg-files.
And everything seems to work just fine.
BUT caution: When updating the first time, I got an error message (installation not being able to overwrite some small file) and the update was aborted, and Vue was gone! The exe file didn't exist.
I tried reinstalling several times, but the basic setup files seem to have been corrupted as well, and I got "out of memory" errors opening the standard libraries (plants, materials, atmospheres etc.)
I had to delete the folder under "Documents and Settings", and then reinstall, and THEN everything worked, incl. the following re-updates. BIG relief!
If you still got problems with the previews, I noticed that at least the cloud previews can be viewed if you do it manually, i. e. not using the icon shortcuts, but the "load object" option, and access the folder. Very strange!
Lars
Hi Gill -
You're wise to hesitate with the update! WAIT until they fix it.
I just found out that none of the custom settings in the "Options" are saved when you exit Vue, e.g. the number of undo's, plant draw quality etc. It goes back to the something very much like the default settings. It's more than just an irritating bug!
I've reverted to the 7.4 beta (new clean re-install of Vue), which had the thing with the noise-TN, but otherwise worked.
About loading the objects: I run XP, and on my system the objects, atmospheres etc. are in an "e-on" folder in the Documents folder. Not "environment" in the programs folder, that's about the application environment.
Attached Link: http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2772456
Oh, the ojbects, plants etc, yes they're in 'Documents' but now all the .PRV files are hidden away in C:UsersUSERNAMEAppDataRoaminge-on softwareVue 7 InfiniteEnvironmentCollectionsI wondered why I could't see them any more in their old folders !
At the top of this reply is a link to the other thread regarding several problems with the new build
Gill
When I save a new .veg file in 7.4 Inf, the plant is ok but the previews aren't saving correctly even though I'm seeing a render in the plant editor.
Gill
