Even for subtle movements?!
Let's say for example.. your hand resting on your stomach.. then your hand starts rubbing your belly. Not much movement at all.. just small circles.
How would you mix the Collar and Shoulder here together? A couple of degrees on one parameter.. say "Front-Back" on Collar, and then a couple of degrees on the same parameter on shoulder?
Maybe I'm misunderstanding what the Collar actually is. Right now I'm under the impression that the Collar and Shoulder are sort of one in the same.
Quote - The shoulder is primary in arm movement. The collar is secondary.
Yep! Usually the shoulder moves a lot more than the collar. How much more probably depends on the pose and how exactly the figure you're using is rigged. You'll have to study your poses and movements and see how much collar movement you need to make things look good.
I don't think in your belly-rubbing example there would be any visible collar movement. But for other similar poses there might be. Just imagine rubbing your hip or waist instead of your belly.
Anyway, I said "both!" because ignoring the collar is a common mistake.
Quote - Maybe I'm misunderstanding what the Collar actually is. Right now I'm under the impression that the Collar and Shoulder are sort of one in the same.
I found the terminology a little confusing. In V4, for example, a movement of the 'Collar' actor will move the model's shoulder in relation to chest and neck, and a movement of the 'Shoulder' actor will move her upper arm in relation to her shoulder. I just tend to think of the 'Shoulder' actor as meaning upper arm, and the 'Collar' actor as meaning shoulder.
When I rub my belly (which I do now because I've had no lunch yet!) I have to make a very conscious effort if I want to stop my shoulder ('Collar') following my upper arm ('Shoulder') movements slightly. If I relax and do it naturally, my shoulder follows... small but definite and noticeable movements. I think it's these missing details that the eye picks up in an animation and the brain subconsciously interprets as "unnatural" or "stiff".
I guess it depends how far you want to go with your animations.
"If I were a shadow, I know I wouldn't like to be half of
what I should be."
Mr Otsuka, the old black tomcat in Kafka on the Shore (Haruki
Murakami)
I always move my collars and shoulders in a 1:2 ratio (one degree of collar to every two degrees of shoulder). I move my necks and heads in the same way, which I think more or less reflects reality.
DPH
Hallo! I've always received great answers on this forum, so I'm back again. :]
I'm currently doing animation.. and I've always wondered: When doing arm movement.. should I be using the Shoulder or the Collar? Or both?
I can think of situations where you'd need both.. the more extreme twists and bends. But what about for subtle movements?
Thanks!
