Sun, Jan 19, 6:33 AM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2025 Jan 15 2:29 am)
Carrara Free Stuff here.
Subject: fountain primitive
holyforest ( ) posted Wed, 27 May 2009 at 6:07 PM · edited Sun, 19 January 2025 at 6:27 AM
Hello,
just curious about to know if someone obtained qood results with the fountain primitive.
Thanks to share your  tips.
Holyforest,
Hundreds of shaders for Carrara
GKDantas ( ) posted Wed, 27 May 2009 at 9:24 PM
Hi Holy... Fountain are good when using the blur object function and for distant visualization. The beter way is using a particle emitter, tha can use metaballs in the render.
Follow me at euQfiz Digital
bwtr ( ) posted Wed, 27 May 2009 at 9:50 PM · edited Wed, 27 May 2009 at 10:05 PM
Holly
I have been searching furiously for a .car file of a "Bouncing Balls"  little movie I made back in Carrara5?. (Using the fountain) It was to emulate that TV add (was it for Windows?) where some one is walking down a street and balls are falling from the sky and bouncing off the road.
(You would have been able to see all the settings from that .car file)
It was pretty easy--well I did it so it must be--by following the Help manual and doing the adjusting in the regular and advanced settings. I had a range of different size and colour balls raining down from the sky using the fountain.
PM me if you would like the (very small) little movie.
Brian
PS-----A bigger movie version is 139MB
bwtr
bwtr ( ) posted Thu, 28 May 2009 at 2:24 AM · edited Thu, 28 May 2009 at 2:26 AM
Just a hint for anybody.( It may be better in more recent versions of Carrara?)
When bouncing the balls off the plane, they tend to sink half way in--which looks a bit odd---I gather the solution is to have an invisible duplicate of the plane just above the original and use that as the target for the bouncing items.
Brian
(And I have given up on trying to find my original .car file---I am really upset!)
bwtr
Xerxes0002 ( ) posted Thu, 28 May 2009 at 11:30 AM
Thanks for the info.. EEEP sorry you have lost your .car file :(
GKDantas ( ) posted Thu, 28 May 2009 at 2:47 PM
I would like to see the movie Bria.. I couldnt understand how you change the triangles for balls...was the shader?
holyforest ( ) posted Thu, 28 May 2009 at 5:37 PM
 Thanks all,
I'm really talking about fountain primitive not the particle emitter :)
Holyforest,
bwtr ( ) posted Thu, 28 May 2009 at 8:45 PM
Sorry Holly
The primitive is just that.
Would any one use that other than in a distant background spot?
I use a gradient shader for interesting effect.
Brian
GKD---guess you found how to replace the triangles items for anything you want.
bwtr
bwtr ( ) posted Thu, 28 May 2009 at 9:54 PM · edited Thu, 28 May 2009 at 9:57 PM
GKD--I did it again I guess, I meant for the Particle emitter.
PM me if you are interested in the emitter movie.
Brian
(my age is showing-----having a few bad days (again) with my mind and my brain in different parts of space!)
bwtr
bwtr ( ) posted Thu, 28 May 2009 at 10:12 PM
And Holly, I meant the Rainbow shader not the colour gradient! Brian
bwtr
GKDantas ( ) posted Fri, 29 May 2009 at 7:57 AM
Hi Brian. if you want you can post your videos done in Carrara in my Carraralounge.com too, this way many users can see your work.
holyforest ( ) posted Fri, 29 May 2009 at 5:15 PM
I did an experiment with metaballs and surface replicator over the fountain primitive, with blur adjustment : the result is quite similar to a water explosion!
Can't find a way to make a correct use of that fountain - supposed to be water.
**Brian : nice psychedelic FX ;)
Holyforest,
