Sat, Jan 25, 11:30 PM CST
Subject: Loss of mouse pointer in Poser 4
moushie ( ) posted Thu, 28 May 2009 at 1:46 PM · edited Sat, 25 January 2025 at 11:23 PM
Does anyone else have the occasional problem of losing the mouse pointer in Poser 4 and having to close out (e.g. via task manager in Vista), and if so is there a solution or a work-around?
geep ( ) posted Thu, 28 May 2009 at 2:09 PM
Try pressing the space bar.
cheers,
dr geep ... :o]
edited 10/5/2019
moushie ( ) posted Thu, 28 May 2009 at 2:19 PM
Thanks, pressing the space bar doesn't help, but I've concluded the problem is in the Prop (PP) file, a building scene. No virus, so it's probably a corrupted file.
lmckenzie ( ) posted Fri, 29 May 2009 at 8:33 AM
If Poser isn't truly dead, you should generally be able to use Alt F to access the File menu and then save your work and quit from there.
moushie ( ) posted Fri, 29 May 2009 at 10:52 AM
Thanks, I'll remember that.
leather-guy ( ) posted Fri, 29 May 2009 at 3:48 PM
I recall having such a problem when I used Poser 4 - I believe I could usually get the cursor back by changing the screen resolution briefly and then changing it back.
moushie ( ) posted Fri, 29 May 2009 at 7:38 PM
Well that's an interesting idea, and thanks. However the problem must be largely a matter of the file itself, a downloaded scene, because it happens even when I've re-downloaded and re-installed the pp2 file, and even after converting it to an Obj file. I appreciate the help.
