Sun, Feb 2, 6:51 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 2:22 am)
Subject: How to create a character with 4 arms? :)
melovewrestling ( ) posted Thu, 28 May 2009 at 10:31 AM · edited Sun, 02 February 2025 at 6:44 AM
Well, I've been thinking about creating a cartoon characters like the monster in Mortal Kombat.
My idea (which could be way wrong) is to put 2 models in the project, then "cut" the arms from one of them and set the new parent to the remaining model.
However I am not really good at "cutting" parts from a model. Anyone can give some insights?
Thanks in advance! :)
hborre ( ) posted Thu, 28 May 2009 at 11:36 AM
A character with four arms does exist over at RuntimeDNA.
http://www.runtimedna.com/Bruizer.html
And there is a morph package available.
Latexluv ( ) posted Thu, 28 May 2009 at 5:44 PM
There once was a 4 armed Vicky 2 or 3. She's still in my runtime somewhere. I once had visions of doing a Shiva render. However, I don't believe anyone has done a 4 armed V4. Shame that.
Weapons of choice:
vagabondallen ( ) posted Thu, 28 May 2009 at 7:45 PM · edited Thu, 28 May 2009 at 7:46 PM
 Depending on how you plan to use it, in some cases you can simply hide all the parts except the arms. I've attached an example. I shrank the duplicate 5% as well for a better over/under shoulder fit.
vagabondallen ( ) posted Thu, 28 May 2009 at 7:50 PM
 I also stacked one body on another for a more "anatomically-correct" four-armed male. Again, hiding the appropriate body parts and such.
Miss Nancy ( ) posted Thu, 28 May 2009 at 10:10 PM
Victoria_468arms package was distrib. by numi et al. in 2002.  he duplicated the arm joint sections in the cr2 file, then changed all instances of joint names, e.g. rShldr became r2Shldr in the second right arm.  it's a rather tricky and time-consuming editing procedure, but it obviates the problem of a second hidden body.
melovewrestling ( ) posted Fri, 29 May 2009 at 5:22 AM
Thanks for the valuable input! :)
Yup hiding the remaining parts came to my mind but when I need to do some action pose, it doesn't seems to work effectively.
I like the idea of the "anatomically-correct" four-armed male approach! But I am not quite sure how to have it done.
Is there a way to .. hmm, say, "cut" the part above the chest of one character, and then "paste" it on top on the chest of other character? (wow in that case we can even make a 8 arms spiderman! :D)
and thanks for the link hborre, that character just look awesome!
Cheers
Tracesl ( ) posted Fri, 29 May 2009 at 9:16 AM · edited Fri, 29 May 2009 at 9:30 AM
I think someone posted a way to do this here in the forums a while ago, going to have to search for it as I could not find the one I was looking for.  It was for M3 but should work for M4.
Also, you may want to check out Free Spider Woman for V4 by AdamThwaites, it has six arms.
momodot ( ) posted Fri, 29 May 2009 at 9:54 AM
I tried to conceptualize a Posette 'space monkey' with a second set of arms in place of legs by parenting two figures together but I could never get it to work as something that made sense "anatomicaly" :(
Wild_Dog ( ) posted Mon, 08 June 2009 at 3:28 PM
Quote -  Depending on how you plan to use it, in some cases you can simply hide all the parts except the arms. I've attached an example. I shrank the duplicate 5% as well for a better over/under shoulder fit.
well, that works a bit, but I decided to try some other ways. Your way works for a one behind the other arangement, but not so much for above and below types. I tried the above and below type, found that increasing the breast size of the female a tad bit worked.
Also, trying to do that anyway for V3- and Aiko3 dosnt work so well, so if you are trying to add arms, best to stick with P4 or V4/A4
