Carrara F.A.Q (Last Updated: 2024 Sep 07 1:44 am)
I haven't run into this issue before.
Just a few trouble shooting suggestions:
try a different HDRI map to see if it is the map creating the problem.
If that doesn't fix it, try rendering with the AG lights off - not knowing what your settings are for the AG lights, they could be the culprit.
if it renders with the original HDRI map and the AG lights off, try enabling the AG lights one at a time and rendering.
Almost 2 MB...its not so much... Try disable the anything glows lights first, maybe GI dont like its effect. You can use glow to simulate neon lights and such thing, without using AG.
Follow me at euQfiz Digital
I already experienced this problem on a Macbook pro.
I noticed that if you disconnect the network (internet or wifi), there is less
crashes. Try to delete temp files and restart the computer.
Holyforest,
Hundreds of shaders for
Carrara
I'm running Carrara 6 Pro on a MacPro, running Leopard.
I'm attempting to render an HDRI render - fairly low resolution: 640x480, 72ppi, nothing fancy. The render gets about halfway through and then Carrara crashes. The scene really isn't complex - one model, a floor and two walls. I've got three Anything Glows lights in place, to replicate flourescent lights.
What can I do to alleviate this problem? Thanks in advance!
