Fri, Jan 31, 10:27 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 31 9:45 am)
Subject: Does DAZ's Injection Magic software work on Poser G2 characters??
MistyLaraCarrara ( ) posted Tue, 02 June 2009 at 12:07 PM · edited Fri, 31 January 2025 at 10:27 AM
This doesn't mention Poser, per se.
www.daz3d.com/i/3d-models/3rd-party-products/injection-magic
I made a dimple morph for Simon, I'd like to offer as a freebie on my website, without infringing.
well, it's hard to see the dimple on this snap.
hborre ( ) posted Tue, 02 June 2009 at 12:50 PM
Yes, Injection Magic will create Morph files for G2 models.
MistyLaraCarrara ( ) posted Tue, 02 June 2009 at 1:46 PM
Thanks!
Just to double check, it does the MAT pose files, too?
hborre ( ) posted Tue, 02 June 2009 at 1:51 PM
I will have to double-check that when I get home from work.  I never used that for MATPose files.  But the conversion is simple enough.  Again, I need to do referencing from home.
hborre ( ) posted Tue, 02 June 2009 at 6:45 PM
Promised to get back to you with answer concerning IM and MATPose files.  The program is primarily designed to create just figure morphs but textures can be included in those created injection files.  The easy workaround is to create your texture changes in the Material Room, save as an .mt5 material file, make a copy and move it to the Pose folder, then open the file with a text editor program.  I use TextPad as opposed to WordPad.  Change the line 'Mtl Collection' to 'Figure', save and then change the format of the file from txt to pz2.  Next time you open Poser and navigate to the Pose folder in your library, you will see a shrugging man with your file's name under it.  You will need to provide your own png thumbnail.
MistyLaraCarrara ( ) posted Wed, 03 June 2009 at 2:21 PM
Thanks.    I have a few of those shrugging guys.
