Wed, Nov 13, 10:36 AM CST
Vue F.A.Q (Last Updated: 2024 Oct 26 8:50 am)
Subject: Require help - Carrara to Vue.....
DarkAtheist ( ) posted Thu, 11 June 2009 at 7:56 AM · edited Sat, 10 August 2024 at 8:07 AM
Hello
This is probably going to seem like a silly question but i am wondering if all the content i have purchased for poser and carrara (sure i wont be able to use carrara stuff) can be used in vue 7.x and if so how would i go about doing this?
I have about 15gb of content and dont feel too hot on the thought of having to reinstall things.
Thanks
lindans ( ) posted Thu, 11 June 2009 at 8:18 AM
You can use poser objects rendered in poser and imported as PZ3 file very easy to do -  most people use this method to place people in a Vue scene. Not sure about Carera
Oh, let the sun beat down upon my face. I am a traveler of both time and space ....Kashmir, Led Zeppelin
DarkAtheist ( ) posted Thu, 11 June 2009 at 8:22 AM
Ah! I forgot about pz3 :) - didn't think i would be able to use carrara files though, i will have to give vue a work over and see what is what.
Thanks
silverblade33 ( ) posted Thu, 11 June 2009 at 8:24 AM
Aye you can import Poser stuff, see tutorial link in my signature for tips on gettign best from Poser imports :)
As for Carrara objects, well export then as obj format and import to Vue?
DarkAtheist ( ) posted Thu, 11 June 2009 at 8:30 AM
Thanks a  lot - looks like some heavy reading, so i think a pot of coffee is in order first :)
silverblade33 ( ) posted Thu, 11 June 2009 at 12:49 PM
Dark Athiest,
well, my tutorial's bit advanced I must admit, but if you learn to set it up good from the beginning, an imported model you can save, and re-use many times, so if it's good at the start... :)
Every app handles materials a bit different, so importing a "generic" item, like a Poser person, can look very different in several apps, if you haven't tweaked it to get the best of the indiviual app's systems.
Oh, don't bother messing with Subsurface Scattering (translucency) for a bit, unless you want to test it to see, it's VERY fiddly to get right a lot of the time! ;)
DarkAtheist ( ) posted Thu, 11 June 2009 at 1:42 PM
I will have a look at it in the morning, and remember to substitute poser for carrara, hopefully saving it as obj and not pz3 should work
Meshbox ( ) posted Mon, 15 June 2009 at 10:38 PM
Vue imports most industry formats very well - OBJ, 3DS, etc. Im reasonably certain that Carrara can export in both of these formats without too much trouble. But does it support exporting the mappings correctly? One of the thing I like about importing stuff into Vue is that, in the case of MAX/3DS to Vue, I can substitute native Vue shaders easily.
Best regards,
chikako
Meshbox Design | 3D Models You Want
ShawnDriscoll ( ) posted Tue, 16 June 2009 at 10:45 PM
For objects I've modeled in Carrara, I UVmap the objects and bake their textures and export them as OBJ for import into Vue.  Then I just apply the baked textures back onto the imported objects in Vue.  I use the Inagoni Baker plugin for Carrara for baking the textures.
If I use the 3DS format from Carrara, I'll lose the ability to re-apply any baked textures and I'll also mess up the objects polygons.
