Wed, Feb 26, 3:41 PM CST
Forum Moderators: RedPhantom
Subject: XP SP3 and problems with Poser 7
dasquid ( ) posted Fri, 12 June 2009 at 11:36 AM · edited Wed, 26 February 2025 at 12:40 PM
I avoided installingSP3 for XP for as long as i could because i read about problems with poser but the other day I had to install it finally and now that I have it is as I feared Poser 7 does not work properly. it hangs at the end of a render (no renders successfully completed since installation os XP SP3) and when I try to do something like delete lights.
Anyone know what the problem is with this damned thing? It is starting to irritate me because I have ideas I need to get out and I cant when i cant get a render done.
thefixer ( ) posted Fri, 12 June 2009 at 12:52 PM
Could always try deleting your prefs and re-doing them, it is usual for corrupted prefs files to cause all sorts of weird problems.
Injustice will be avenged.
Cofiwch Dryweryn.
dasquid ( ) posted Fri, 12 June 2009 at 12:57 PM
Quote - Could always try deleting your prefs and re-doing them, it is usual for corrupted prefs files to cause all sorts of weird problems.
What file am I looking for in particular?
richardson ( ) posted Fri, 12 June 2009 at 1:13 PM
Jules53757 ( ) posted Fri, 12 June 2009 at 1:17 PM
May be XP3 installed an other Graphics driver, check for the latest version
Ulli
dasquid ( ) posted Fri, 12 June 2009 at 1:24 PM
Ok Thanks Went through it and cant find a damned thing that they say to delete.
thefixer ( ) posted Fri, 12 June 2009 at 1:36 PM
Try looking in Appdata, it could be a hidden folder in there, I'm not familar with XP3.
It's in Appdata for Poser 7 with Vista.
Cofiwch Dryweryn.
thefixer ( ) posted Fri, 12 June 2009 at 1:37 PM
Appdata/Roaming/Poser 7, that's the path in Vista.
Cofiwch Dryweryn.
markschum ( ) posted Fri, 12 June 2009 at 1:40 PM · edited Fri, 12 June 2009 at 1:41 PM
in XP for Poser 7 your files are located in C:documents and settingsUSERapplication DataPoser 7
In Poser 6 and earlier they are in the program folder.
there should be poser.ini, libraryprefs.xml and ui xxxx prefs.xml where xxx is screen resolution
You can delete all of them if needed to reset poser back to tts install stage . You will need to add any external runtimes again if you delete libraryprefs.xml
dasquid ( ) posted Fri, 12 June 2009 at 1:40 PM
I seem to have fixed it.
I went to general preferences under edit and reset it to open  as factory preset and  then it both allowed me to delete a light AND render to completion. Ill find out if it is really fixed when i  try a more complicated render tonight lol.
Thanks for the help everyone.
dasquid ( ) posted Fri, 12 June 2009 at 1:41 PM
Quote - in XP for Poser 7 your files are located in C:documents and settingsUSERapplication DataPoser 7
Yeah Mark thats the crazy thing my Xp pro doesnt have a documents and settings folder in the /c: area.
Khai-J-Bach ( ) posted Fri, 12 June 2009 at 1:42 PM
the path is
C:Documents and SettingsYourusernamehereApplication DataPoser 7
if you cannot see Application Data
open my computer, goto Tools, Folder Options, View then turn on "Show Hidden Files and Folders'
you will now be able to see the Application Data Folder.
dasquid ( ) posted Fri, 12 June 2009 at 1:52 PM
I have already done the show hidden  thing and still cant find it lol
