Wed, Jan 22, 5:17 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 22 5:13 am)
Subject: Because I'm into self-torture...how do you make earring props conforming?
LaurieA ( ) posted Fri, 19 June 2009 at 8:56 PM · edited Tue, 07 January 2025 at 6:57 PM
Give me the short list (if there is one) or point me to a tute please if you can. I have these nice earring props I made years ago and I'd like to give them away as conformers for Kali and Kena. I figure conforming them would be easier for the end user to, well, use ;o). It's something I should probably learn anyway ;o).
Thanks in advance,
LaurieA ( ) posted Fri, 19 June 2009 at 9:14 PM
The earrings in question on Kena:
DarkEdge ( ) posted Fri, 19 June 2009 at 9:28 PM
If it where me, I would just smart parent them....no need to conform them.
LaurieA ( ) posted Fri, 19 June 2009 at 9:46 PM
I know, but:
I can't figure out how to smart prop in Poser 6/7 (was easier in 4), and I want to learn how to create something conforming, so I figured why not the earrings? ;o).
DarkEdge ( ) posted Fri, 19 June 2009 at 10:19 PM
Okay. Conforming stuff will deform and bend them (ie; the earrings), that won't look good. These need to be smart parented, this way they will retain their original shape and follow the head. Also, the earrings need to come onto the stage in the right or correct position.
Mini Tut: Load figure, load earrings, position earrings, export earrings as wavefront obj. Now use that obj file because you have positioned them correctly.
New Scene: Load figure, load obj (earrings positioned correctly), select earrings and click on the Propertes panel and press SetParent button, select the figures head from the drop down menu, now save earrings to Props library. You should recieve a warning telling you that you are saving a SmartProp, acknowledge yes and now you're done.
Delete earrings from stage, load Props earrings and try moving the figures head...the earrings should follow automatically. 😄
LaurieA ( ) posted Sat, 20 June 2009 at 12:44 AM
Thanks VERY much DarkEdge: I'll give it a shot. :o). I'll let you know how it went.
lesbentley ( ) posted Sat, 20 June 2009 at 12:38 PM
I agree with DarkEdge that it is probably best to have the earrings as smart props. When Poser refuses to save something as a smart prop it is because you have used "Select Subset" when saving the prop. If you need to use "Select Subset" to include two or more objects in a pp2 (prop) file, then you will need to edit the pp2 to turn it into a smart prop. Open the pp2 in a text editor. Search for any lines that begin with "parent", edit these lines to use "smartparent" and the name of the parent actor, eg:
smartparent head
If the earrings were made up of multiple objects, eg a ring and a pendant parented to the ring, then you would only only need to smartparent the ring part to the head.
LaurieA ( ) posted Sat, 20 June 2009 at 2:18 PM · edited Sat, 20 June 2009 at 2:20 PM
I've made smart props of them according to DarkEdge's directions and they work a charm. After I exported them as objects and then imported them back in, THEN they asked of I wanted to save them as smart props ;o). Couldn't figure out why they wouldn't before.
Thanks DarkEdge!!
DarksealStudios ( ) posted Wed, 24 June 2009 at 4:11 PM
Ok, from this step I would like to know...... Where is my .pp2 file? I've done the same as listed above, saved to prop library and have no problem for the steps above. But, when i go to my props folder and subfolder I have no .pp2?? I'm using poser 6. Any clues for me?
My Store   My Gallery    Contact
DarksealStudios ( ) posted Wed, 24 June 2009 at 6:12 PM
OK!!! no matter what...... dont do what windows wants!!
Turned off the UAC..... I had to redo my library saves (no biggie, only 2) but this time it made the pp2 file. Thanks guys!
DarkEdge ( ) posted Wed, 24 June 2009 at 6:21 PM
Glad you figured it out! 😉
MistyLaraCarrara ( ) posted Fri, 26 June 2009 at 12:02 PM
What happens if she's not in her default pose, when you add the earrings?
just wondering how smart are smart props.
LaurieA ( ) posted Fri, 26 June 2009 at 12:22 PM · edited Fri, 26 June 2009 at 12:22 PM
They still go to where you smart propped them. In this case, parts of her ears. They inherit the bends of the parent.
