Tue, Nov 19, 6:39 PM CST
Subject: How to keep a figure in same place when pose button used?
ecccoman ( ) posted Mon, 22 June 2009 at 2:18 PM · edited Tue, 19 November 2024 at 6:36 PM
When I use a pose button with a figure, the figure jumps to some other area of the scene (I suppose it is going to the spot where I originally set up the pose button.  Is there a way to keep the figure in place?
I also notices that this happens with some preset poses, but not others.
I have been spending a lot of time dragging figures around scenes.
Thanks.
hborre ( ) posted Mon, 22 June 2009 at 2:42 PM
Are you creating the poses yourself and saving them into your library?  Or are they purchased poses?
markschum ( ) posted Mon, 22 June 2009 at 3:59 PM
the pose can have values for translation in either the hip or the Body . Load the pose, check the translation dials in both parts, zero them and save the pose with a new name
lesbentley ( ) posted Mon, 22 June 2009 at 8:32 PM · edited Mon, 22 June 2009 at 8:36 PM
The jumping to a different place is caused by translations of the hip actor. Any translations of the hip saved in the pose file will replace any current translations in the hip of the character you are applying the pose to. Poser does not save pose data for the Body actor, so...
To avoid this problem in poses you make your self, never use xTran or zTran in the hip, use them in the Body instead. With yTran do use it in the hip, not the Body (you want yTran to be remembered so that the feet will end up on the ground).
ghost6677 ( ) posted Tue, 23 June 2009 at 1:45 AM
Not sure, but is it really the hip only? isnt there a checkbox called bodytransformation when saving a pose? i thought that would store the translation of the body. if not what does that checkbox.... wrong assumption?
just wanted to throw it in the room ;)
markschum ( ) posted Tue, 23 June 2009 at 10:33 AM
yes Ghost, in Poser 7 they added a checkbox to save body transforms. Thats translations, rotations and I think scale of the Body actor.  The saved pose works in any version of poser. Once the info is in the pose file poser will apply it.
It sort of sucks in a major way cause people have been learning for years NOT to use Body in animations , cause they dont save. I dont know what happens when you save a pz3 file :(
lesbentley ( ) posted Wed, 24 June 2009 at 6:04 AM · edited Wed, 24 June 2009 at 6:07 AM
@ ghost6677,
Yes, I should have said:
Poser does not save pose data for the Body actor - except in versions after P6, if you use the checkbox to save body transforms.
When people ask a question, and don't specify what Poser version the question relates to, I don't usually specify what Poser version the answer relates to. ;)
