Thu, Dec 12, 2:37 PM CST
Forum Moderators: Staff
Subject: Is there any way to make the Translate tool really translate?
ockham ( ) posted Tue, 23 June 2009 at 11:02 AM · edited Sat, 07 December 2024 at 9:39 AM
I've always run into this problem with inorganic figures, but it's getting more irritating lately.
This abacus is a perfect illustration.... you should be able to use the translate tool like a finger
to manually click the beads up and down.  The translate tool does actually translate
when you apply it to the BODY or the "hip-like part".  But when used on any body part
lower in the hierarchy, the translate tool actually rotates the item.
This makes sense on a human or animal.  When you want to pull an arm, you're
actually rotating.  But it's wrong on an abacus or a pot lid or a phone handset.
Any ideas?
My python page
My ShareCG freebies
MistyLaraCarrara ( ) posted Tue, 23 June 2009 at 1:54 PM
The joint editor lets you change the xyz order.  maybe one of those other settings for the beads?
I was working on animating doors in a door frame last night. Rotate Y only, I wish.  It kept rotating across the axises.  I wish I could have slammed the door, it was aggravating.
ockham ( ) posted Tue, 23 June 2009 at 2:06 PM · edited Tue, 23 June 2009 at 2:07 PM
Yup, that's a related problem, and equally annoying.
You can solve your problem by "clamping" the max and min for every rotation you don't want.
And I do mean every rotation .... not just on the door itself, but on the wall
it's mounted in.
For instance, here are the Y,X,Z rotation parameters for the door with the
other axes "clamped":
        rotateY yrot
            name Open
            initValue 0
            hidden 0
            forceLimits 1
            min -100
            max 0
            trackingScale 1
            keys
                static  0
                k  0  0
            interpStyleLocked 0
        rotateZ zrot
            name zrot
            initValue 0
            hidden 1
            forceLimits 1
            min 0
            max 0
            trackingScale 1
            keys
                static  0
                k  0  0
            interpStyleLocked 0
        rotateX xrot
            name xrot
            initValue 0
            hidden 1
            forceLimits 1
            min 0
            max 0
            trackingScale 1
            keys
                static  0
                k  0  0
            interpStyleLocked 0
Note the 'forceLimits 1' , and the max and min are both 0 in the X and Z parameters.
(The Y rot has more typical limits for a door.)
You'd then write the same "clamp" in all three rotations for the wall that the door
is mounted on, because Poser will try to rotate that wall when it finds that it
can't move the door in all three axes.
My python page
My ShareCG freebies
MistyLaraCarrara ( ) posted Tue, 23 June 2009 at 2:31 PM
thanks.
markschum ( ) posted Tue, 23 June 2009 at 4:19 PM
I usew forcelimits 4, it doesnt turn off
ockham , have you got the bead axis aligned to the frame ?
ockham ( ) posted Tue, 23 June 2009 at 4:26 PM
Hmm.  I always use PHI files for setup.....
When I look at it now in the setup room, the bone for each bead starts from
the top center of the bead and points straight down.
Does that sound like the proper alignment?
My python page
My ShareCG freebies
lesbentley ( ) posted Tue, 23 June 2009 at 8:39 PM
Yes the thing about the translate tool and actors is a real PITA when it comes to mechanical figures. For an abacus I think you could fix it by putting the geometry of the frame in the BODY actor, then making the beads children of the BODY, then deleting the unused translate channels from the beads. This fix comes at a price though. By putting geometry in the BODY you loose a defence against gimball lock.
In more complex figures making everything a child of the BODY would not be a viable option.
Having the beads as props, rather than actors, would be another option, though that has its own downsides.
I don't think alignment of the bones is anything to do with the problem you are having. This just seems to be the way that Poser works. Perhaps there is some proper fix, but I don't know what it is.
ockham ( ) posted Tue, 23 June 2009 at 8:49 PM
I'll try your first idea and see what happens.  Seems strange enough that it
just might work!
I thought about doing the set-of-props, because I know translate does work
in that case, but it just seemed way too cumbersome for 46 parts.
My python page
My ShareCG freebies
ockham ( ) posted Tue, 23 June 2009 at 9:16 PM
Turns out I didn't even need to go that far.  The beads were childs of the Rods,
which were separate parts.  I merged the Rods with the outer frame, and made
the beads direct childs of the frame.  This eliminated the tendency to rotate.
Then I deleted the Xtran and Ztran channels.  Now the translation tool
moves them neatly up and down!
Great suggestions!
My python page
My ShareCG freebies
lesbentley ( ) posted Wed, 24 June 2009 at 9:58 AM
file_433475.TXT
Hu!!!
Let me see if I have this right. You have beads parented to a frame and the frame is parented to the BODY, and it works?
I did a test rig with just that set up, and it does not work for me in P6, the beads won't slide with the cursor! I'll attach the file in case you want to see for yourself.
The cr2 uses internal geometry, but I can't see that making a difference. Also I deleted all the channels from the "beads" (actually cubes) except the yTran, but I can't see that being to blame either. I don't know what gives here, why does it work for you, but not for me?  The only way I can get it to work is by making the beads children of the BODY.
ockham ( ) posted Wed, 24 June 2009 at 10:21 AM
Attached Link: abacus
Here's the complete item so you can try it out.  I don't know why this exact combination works, but it does for me!  Maybe it won't for you....?
My python page
My ShareCG freebies
ockham ( ) posted Wed, 24 June 2009 at 6:10 PM
Looking at your setup, I see you're using MinFig, and each of the
mesh items is written like a prop with its own material.
Maybe that arrangement fools Poser into thinking it's just a collection of props,
in which case the translate tool would translate anyway....?
My python page
My ShareCG freebies
lesbentley ( ) posted Thu, 25 June 2009 at 5:20 AM
Ah! It all becomes clear now. In a previous post you said, quote:
"I merged the Rods with the outer frame, and made the beads direct childs of the frame."
But looking at your cr2, the beads are actually children of the BODY, not the frame, and moving the frame leaves the beads behind. I thought you had managed to make the beads children of the frame and still have them sliding, which lead to my confusion.
ockham ( ) posted Thu, 25 June 2009 at 9:01 AM
Yup, you're right.  So I went ahead and followed your original suggestion all the way,
(BODY is actually the frame) and this time it worked.   Not sure why it didn't work
the first time.   Again thanks for the suggestion!
This is going to be a freebie intended for educational use, with a script to animate
addition, so the unconventional arrangement doesn't matter as it would in a product.
The only thing that matters is easy operation.
My python page
My ShareCG freebies
ockham ( ) posted Thu, 25 June 2009 at 3:57 PM · edited Thu, 25 June 2009 at 4:01 PM
Summarizing for future readers and for my own dim memory:
The Translate tool will only translate when the item you click is either...
(1) a prop (doesn't matter if it's free-standing or parented)
(2) a BODY
(3) a "hip-like" body part, which means it's an immediate child of BODY.
In this case, Les's ingenious solution was to place the frame in the BODY
spot of the figure.   This is highly non-standard but works just fine.
Then all of the beads could be first-level children of the BODY.
This wouldn't work if the translatable part was farther down in the hierarchy,
with no way to place it in the "hip spot".
My python page
My ShareCG freebies
