Carrara F.A.Q (Last Updated: 2024 Nov 05 6:06 am)
I think that above folks have the best solution. Unfortunately, the only way to really lower the horizon is in the sky mode (Mark, you may want to step in here if I'm full of hooey) even though both mode show the Horizon Altitude that you can plug say -22 inches, it works in the sky mode but I can't get it to do squat in the realistic sky mode (yeah, if I lower the puppy to -3000, I get the Earth's curvature-a nice grey curved surface-at least in Carrara 5 Pro). Jan
I'd like to do some realistic sky images that do not have either a ground OR that white cloud layer that persists even after you uncheck "enable ground" but I can't figure out how to do it.
Essentially, I want the sky to keep going "down" without hitting that cloud "floor."
If you're not sure what I mean, set up a pic with realistic sky and uncheck "enable ground" and you'll see that there's still, essentially, a ground.
I want empty space.
Does anyone know how to get rid of that?
