Sun, Jan 26, 7:48 PM CST
Subject: Incidence Invisibility-Q&A for Material Room gurus
JOELGLAINE ( ) posted Thu, 25 June 2009 at 6:23 PM · edited Sun, 26 January 2025 at 7:45 PM
I have a puzzling question for all the Material Room gurus like BagginsBill and others.
I had read last week on one of the CG forums on the web about something called (I think)  Incidental Invisibilty.  That may not be the actual term, but it was 100F+ in the room when I was reading, so my memory fails from hardware melting. :laugh:
What I mean is this: As the edge of area (like the cylinder of a light-sabre)  approaches the center, the texture of the ambient mateial becomes more visible.  The article went on to talk how it only works on cylinders and such, but NOT flat swords because of something dealing with 'Angle of incidence" due to the curvature of the mesh.
I would guess that mean as the Viewer (Eye or camera) is at a 90 degree angle to the mesh with this shader node on it, it appears completely solid, but the more it curves away from you, the more transparent it becomes until at the "edge on" of the mesh, it's invisible.
My question is this: Is this possible in the poser material room?
I have no immediate use for this, but the thought of blaster bolts and light-sabres with more "Realistic" (oh do shut up! :laugh: ) appearance would be a real boon to start with. If something exists, someone will use it!
I cannot save the world. Only my little piece of it. If we all act together, we can save the world.--Nelson Mandela
An  inconsistent hobgoblin is the fool of little minds
Taking "Just do it" to a whole new level!
IsaoShi ( ) posted Thu, 25 June 2009 at 6:45 PM
Yes. The Edge_Blend node does this. You can use it to control any effect, not just transparency.
pjz99 ( ) posted Thu, 25 June 2009 at 6:51 PM
Sounds like an application of the Fresnel effect (I would give you the link to the RDNA thread on same but that's history now).  I have a render going just now or else I'd dig up a material that has this implemented and give you a screenshot, as Isaoshi says I believe it features Edge_blend node to control reflectivity based in the angle of the surface in relation to the camera (swiped from Bagginsbill's example).
My Freebies
JOELGLAINE ( ) posted Thu, 25 June 2009 at 7:00 PM
Really?  Wow, that is SO cool!  I'll have to play around in the material room some more tonight!  So many hours in it, LOLOLOLOL:laugh:
IsaoShi ( ) posted Thu, 25 June 2009 at 7:08 PM · edited Thu, 25 June 2009 at 7:15 PM
Here's a quick render of an Edge_Blend node controlling Transparency. By adjusting the Attenuation value on the node, you can control the transition rate between the two colour values that you specify for 0 and 90 degrees incidence. I just used white (opaque) and black (transparent) in this example, with Attenuation = 1.
(edit) oops, the Edge_Blend node was also controlling diffuse colour in this image, not just transparency.
pjz99 ( ) posted Thu, 25 June 2009 at 7:20 PM
If you were trying to fake something like a lightsaber you might try the same thing but with the Ambient_Color and value channels.
My Freebies
bagginsbill ( ) posted Thu, 25 June 2009 at 7:59 PM
Of course there is Transparency_Edge and Transparency_Falloff - hehehe.
bagginsbill ( ) posted Thu, 25 June 2009 at 8:02 PM · edited Thu, 25 June 2009 at 8:03 PM
Are we talking about a glowing cylinder? The idea being that when you look "through" the middle of it, the glowing bits are more dense, whereas when you look near the edge, you're looking through less glowing bits?
If that's the case, Edge_Blend'ing doesn't work so great - point the cylinder/sword at your camera - it's all edge then  At such an angle, you'd be looking through 10 times as much glowing stuff so it should be MORE dense, not less.
What you really need for this is a volumetric shader, like my new cloud-puff shader.
bagginsbill ( ) posted Thu, 25 June 2009 at 8:07 PM
Observe.
pjz99 ( ) posted Thu, 25 June 2009 at 8:16 PM
The interior is great, but how about the ends?  Does backfacing geometry or the end caps of the cylinder work against you here?  If so it wouldn't take me 5 seconds to give you a cap-less cylinder OBJ.
My Freebies
bagginsbill ( ) posted Thu, 25 June 2009 at 8:31 PM
I wasn't worried about the caps because of course you can make it capless, or tapered, or whatever.
The real issue is as the sword points towards the camera, it disappears. That's not how it should work. it should do the opposite - becoming more opaque because at that angle you're looking through more of it.
bagginsbill ( ) posted Thu, 25 June 2009 at 8:35 PM · edited Thu, 25 June 2009 at 8:35 PM
Look here:
http://www.renderosity.com/mod/forumpro/showthread.php?message_id=3072203&ebot_calc_page#message_3072203
Back in 2007 I helped Molina00 design a light saber. The trick is to use a series of concentric cylinders, each with a different transparency. This is, in effect, simulating a volumetric shader, because we're sampling the volume at many points in the interior. It works great.
pjz99 ( ) posted Thu, 25 June 2009 at 8:46 PM
That's pretty smart, looks great also.
My Freebies
bagginsbill ( ) posted Thu, 25 June 2009 at 8:47 PM
Here's the link to it if you wanna see how it works.
http://www.sharecg.com/v/14198/poser/Energy-Sword-v.1
JOELGLAINE ( ) posted Fri, 26 June 2009 at 2:49 AM
That's pretty clever.  That's sort of like faking a cane of light with multiple cone props, like I saw a few years ago.  I've d/led it and will take a look at it.
lesbentley ( ) posted Fri, 26 June 2009 at 4:44 AM
I'm interested in the effect in IsaoShi's first image. I would like to be able to simulate the glow around a candle flame or street lamp. I don't want to have to use a multi-layer prop as in bagginsbill's suggestion for a light sabre, and as I only want to use this on a sphere, I don't think the same problems of camera angle apply. The only problems in IsaoShi's image are the grey appearance around the edge of the sphere, I would need it much lighter, I would also need the edge to fade to 100% transparent.
I'm a total dunce in the material room. Could someone post a screen shot of the set up, or instructions of how to do this?
JOELGLAINE ( ) posted Fri, 26 June 2009 at 5:10 AM
Street lamp, candle flame and such was what I was thinking might have uses for this effect. I haven't had a chance to play in Poser since posting.  I'm in the middle of moving today.
IsaoShi ( ) posted Fri, 26 June 2009 at 5:43 AM
lesbentley: I'm at work now, so I can't post any setup shot, but I'm sure others will point you in one or other suitable direction.
As bb said, if you only want to adjust transparency you could use the Transparency_Edge and Transparency_Falloff channels on the PoserSurface. Increase the Transparency_Edge value to soften the edge, and play with the fall-off value to get the transition you want between zero and full transparency.
My test sphere was only grey around the edges because I inadvertently used the Edge_Blend node to reduce the diffuse colour, as well as to increase the transparency. My shader was already set up like this, and I forgot to unplug it before rendering, and I was too tired to do it again.
raven ( ) posted Fri, 26 June 2009 at 10:49 AM
lesbentley, is this the sort of thing you were after? This is a simple glowball material that fakes the glow around a lightsource on a ball prop. It's what I've used to fake lightglow in Poser for ages, and is set up as IsaoShi states.
raven ( ) posted Fri, 26 June 2009 at 10:50 AM
This is the material setting I use on my glowball prop.
bagginsbill ( ) posted Fri, 26 June 2009 at 11:25 AM · edited Fri, 26 June 2009 at 11:25 AM
That looks really great, Raven. Elegant in its simplicity, too.
scarlock ( ) posted Fri, 26 June 2009 at 1:47 PM
Is this one of the times it is ok to use Reflection_Lite_Mult?
raven ( ) posted Fri, 26 June 2009 at 2:13 PM
To be honest, it's an old shader I use and I forgot all about that. Normally I untick that after reading bb say it's wrong. I wish there was a Python script to automate turning it off!
Here's the same scene with it unticked. I can't see a difference, but I believe that setting is to do more with reflections rather than anything else. I could be wrong though! :)
bagginsbill ( ) posted Fri, 26 June 2009 at 2:51 PM
That setting only affects what is plugged into ReflectIon_Color. In this case it doesn't do anything bad or good.
lesbentley ( ) posted Fri, 26 June 2009 at 6:47 PM
Quote - lesbentley, is this the sort of thing you were after?
Yes, that's exactly the sort of thing I was looking for. Thanks raven.
JOELGLAINE ( ) posted Fri, 26 June 2009 at 7:50 PM
Damn, Rave, that kicks ass!  W00t for you!
If Bagginsbill likes it, that IS high praise indeed!  He never likes anything!  <<  >>
:laugh: LOLOLOLOLOLOLOL
hborre ( ) posted Fri, 26 June 2009 at 8:13 PM
Online Now!
Be careful, he will charge you premium rates for his next freebies.
