Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 22 1:36 am)
try to export it as an .obj... then just uncheck everything and check the one that says "as a morph target" thats what i do with morphs i make for body parts... you can try it for the hair... its worth a shot.. if that works.. then you can just include that in a zip with the instructions on how to scale it and all...
She looks adorable, great work on the morph targets! c0mputernerd is right, just export the object as a morph target with none of the other boxes checked and it will work fine. You will also want to go to Bushi's web site and download his morph squeeze utility, this takes out all of the polys whilsht still leaving the vertices intact, protecting the authors copyright and also drastically cutting down on file sizes.
Make sure you get Kozaburo's permission before you distribute sqeezed .obj morph targets. Squeezed .obj MT's are only legal for DAZ items because DAZ has given permission for people to use them. You need to get the individual authors' permission to distribute squeezed MT's for other authors' work. The hair looks great!
