Here is the promised mask - actually a PSD file with an adjustment layer so you can modify the radius easily if you don't like what's there, and two outputs from same in JPG format.
http://cid-b233dcaeefa9709c.skydrive.live.com/self.aspx/Public/Poser%20Freebies/V4%20Lip%20Mask/V4-Lip-Mask.zip
I'll have a couple of samples using it in a minute.
Quote - > Quote - You know there is a pretty serious argument against this. Unless you do equally non-easy things, you will be forcing Poser to load an entire 48 megabyte image just for the alternate colored lips. You'd be really taxing your system for no reason then.
While I don't think many people do this, there's a way to just load a crop of the texture and then use the U/V_Scale and U/V_Offset params to position and size the image crop where it needs to be, it doesn't have to be 4000x4000 (takes rather a lot of trial and error though).
Heheh. That is precisely what I meant when I said "Unless you do equally non-easy things".
I've seen a few people try this but nobody did it commercially.
Heheh. That is precisely what I meant when I said "Unless you do equally non-easy things".I've seen a few people try this but nobody did it commercially.
Maybe because such a setup would not work in D|S, at least not before 3.0? No idea if the new shader blocks are powerfull enough for stuff like this...
A ship in port is safe;
but that is not what ships are built for.
-"Amazing
Grace" Hopper
Avatar image of me done by Chidori.
Here is what you can have with a lot of mask with victoria 4 ! In this configuration, skin head and lips have the same material zone.
Dont forget the colors :biggrin:
Génération mobiles Le Forum / Le Site
Actually that setup can be used in other apps, you just need to fool around with their materials settings - even basic D|S can use a blending mask, and Cinema 4D can use a layer shader in any channel with a mask like this (I'm certain other apps can also). Most casual users just don't poke around in materials settings though.
Do note that if you're interested in customizing your figure a bit, it isn't very hard to consolidate the polygon groups in the OBJ of a figure using Poser's group editor and re-export the OBJ to a different filename, and then remove the unneeded materials in a copy of the CR2 (not redistributable though, copyrighted material) and point the copy of the CR2 to the copy of the OBJ.
My Freebies
