goto tool bar >Render >Materials select the eyelashes set the transparency min to 100 set the transparency max to 100 set the transparency falloff to 0 be sure the trans map is loaded and the texture map is loaded render and see if that work stallion
You might as well PAY attention, because you can't afford FREE speech
