Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 10:01 am)
Hmmm... that is odd. I usually have very few problems with Poser 6. I can fill up a scene with no problems. However, I don't frequently try multiple human figures, but I've had 2 human figures and maybe some type of animal or creature in there.
I'm running a PC:
2140 @1.60ghz dual core proc
3 gig of ram.
My video is on the board (ugh...really bad)
Oh, then if clothes count.
I had
-James,:Hair for james( with texture), sunglasses for james, , shirt and pants, shoes
-V3: Skirt, blouse, neckless, highheels, Hair( with texture). ,
-Matt, with pants and shirt and shoes, and hair
So that's about 16 characters...
PLUS MATT And all the characters use high quality textures for the skin and Eyes
But i'm not even complaining about rendering yet!! I'm just saying that I run out of memory just for loading these characters into the scene.
Wel well, i guess i have to change what i want to do. I originally wanted to form groups of crowds of 2 or 3 characters. but since i can't do 3, i'll do 2. 2 is possible!
I was going to do a family of 3 or 4. but i guess i can't
Ok i'm back, in case anyone is seeing this thread. I did a test where i left V3 in, but deleted her hair. ANd guess what? I did get an ERROR when trying to open that file.
Which means, the hair is not the problem. It's v3. But i doubt it v3 is giving the problem... it must be the Body texture that i used for that v3. I'll test.
YES!! Cause all the Pz3 files with 2 characters where i have V3 use this texture give me that error when i open the file. While the Pz3 2 character file with v3 using a different texture, doesn't give me an error.
DOES POSER 6 just go crazy after a while of use? I had nt had any problem with v3 before, and i have not moved the textures around in my computer
But why would it be giving me errors when i have used and loaded that v3 with that texture many times before...
Ok , tested the Texture, .. instead of using that texture. i applied the DAZ v3 texture and resaved file. When i opened, i still got the error.
ok, my final say will be is that Sometimes when you save files, Poser 6 creates bad data in some Pz3 files. Then even if you open that file and try to get rid of the error by SAVING AS and giving it a new name.. you'll still get the error cause the bad data that was written before, remains there.
So, my fix will be to create a new Pz3 with 2 characters from scratch. I will not try to open that first file i made and SAVE AS with a new name. I will not do that.
What kind of hair does V3 have? Maybe you are using freebies that were built from the hair room, not a conforming hair or a hair smart prop.
If you are using the one from the hair room then it might be the one triggering your memory problem because hair strands is composed of lots of polys.
Better solution: BUY A NEW COMPUTER.
Passion is anger and love combined. So if it looks
angry, give it some love!
well guys I fixed the problem. All was just like i had thought. Some poser file corruption. So i started a new file from scratch and loaded my characters, then saved. And
now those files open fine.
But aside from that litle problem i had, it's really tedious trying to work with 3 or more characters at a time. My system gets so slow
Here, let me help.
Poser PMD files do not work. Turn off external binary morph targets.
PMD files have been discussed a BILLION times. They don't work.
Don't use PMD files.
Your error message said "or PMD files are invalid."
That's because all PMD files are invalid.
PMD does not work.
Oh, did I mention PMD files can be a problem?
Hehehehe.
Quote - Ok , tested the Texture, .. instead of using that texture. i applied the DAZ v3 texture and resaved file. When i opened, i still got the error.
That is probably because you applied more than a texture. You probably applied a character, which included morphs. When you saved it, you saved it with PMD morph information. Changing the texture after that makes no difference. You already broke it.
It's included because it sometimes works, but rather than try to explain when you can and cannot use it, we just say turn it off. If you forget to follow the details of when you must stop using it, you'll lose a day of work - better to just deal with slower saves.
V4 in partciular has something different about her that makes her not compatible with PMD files.
Quote - It's included because it sometimes works, but rather than try to explain when you can and cannot use it, we just say turn it off. If you forget to follow the details of when you must stop using it, you'll lose a day of work - better to just deal with slower saves.
Not having a problem using PMD files, it just takes my computer forever to locate the file...hmmmm
I wonder if that's why it takes so long, it doesn't really work?
2GB of RAM is part of your problem too I reckon. For multi-figure renders you really need more. I used to be limited to 2 Vicky 4s in a scene. Upgrading my RAM to 4GB and using the /3GB switch allows me to do a lot more. Since the upgrade I've already managed one scene with 5 fully clothed Vicky 4s and I reckon I might manage to squeeze a bit more in.
Thats in Poser 7 running on WinXP SP2.
If a complete PC upgrade is out of the question a RAM upgrade would be a good investment if you want to do multi-figure scenes.
Expert in computer code
including, but not limited to, BTW; IIRC; IMHO; LMAO; BRB; OIC;
ROFL; TTYL. Black belt in Google-fu.
Why do you reckon that? Am I missing something? The error said it could be memory, or it could be invalid PMD files.
The OP got the error even with only two figures loaded, until he stopped using PMD files.
Which part of that information says he should continue to investigate memory as an issue?
Right, but sluggishness during posing is not memory - it's CPU.
Posing with OpenGL preview will also be affected by a graphics card, since in that case it is the GPU doing the drawing in real time
I'm not very familiar with Mac hardware, but if I understand correctly, the G5 CPU came in many flavors. According to Wikipedia, in May 2005, the 1.8 Ghz was no longer sold, which would place your box at 4+ years old.You didn't say which variant you have. If you have the single-core SP unit, with the slower 600 Mhz front side bus, then you have a very slow machine indeed by today's standards.
However, if you're posing with OpenGL, then the GPU is the bigger issue. Wikipedia doesn't mention what sort of graphics processors came with those units, but given the time frame, I'd say they are not able to handle posing with half a million or so polygons in anything like real time, no matter how much RAM you add.
Is your computer an iMac? Just curious. Doing research on the G5, I read that some of the iMac units can't display all colors because they had a 6-bit display, not 8-bit like the rest of the universe. Apple got sued over that, because they claimed it could display millions of colors, when in fact it is only 262 thousand colors. I suspect the real-time graphics chip in it was very limited in power, as well.
You could buy a faster PC, used, for $150.
Quote - Bagginsbill.. I also wrote that even aside from the fact that i was able to get rid of the error after the PDM thing, my poser gets really sluggish, in a scene with 3 fully clothed characters.
That's why he mentioned memory
Indeedy. The thread title asks for best computer specs to make populated scenes. Can't do better than ram more RAM at them.
You may want to try if a different preview style results in faster performance. The FX5200 isn't the fastest card to begin with, and since OS X uses OpenGL heavily for it's UI, your scene's textures have to fight over the 64MB VRAM with the rest of the system.
Try if switching to Smooth Shaded instead of Texture Shaded mode improves things for you.
Quote - > Quote - Bagginsbill.. I also wrote that even aside from the fact that i was able to get rid of the error after the PDM thing, my poser gets really sluggish, in a scene with 3 fully clothed characters.
Except he has 2 Gigs of RAM already, which is enough for 10 figures, as that is all I have and I don't have the problems tebop is experiencing.
Are you at all following the conversation? We're dealing here with a slow CPU, a slow front side bus, a very slow GPU, and only 64K of VRAM. He can put 64 Gigs of RAM in his computer and it won't make a bit of difference. Are you going to pay for the RAM upgrade that isn't going to do anything here? For the price of 2Gigs of RAM, tebop can have a whole new computer that blows this one away.
Please, pay attention to the things being said instead of just repeating yourself.
Agree with BB, my rig is a celeron dual@2.0Ghz with only 2 gigs in ram, and I'm able to put, say 5 to 9 figures(this is counting clothes) an have the same speed... well that was made just to test, I usually work with 2 or 3, max 5 figures...
that rig isn't VEEEEERY expensive.
so if you're lookin foward to get a new rig... first you might try to see how much money you can spend, and stick to it. nowadays computers are gettin cheaper every day.
Quote - If it's CPU.. then, are you saying Mac G5, 1.8GZh users, should not expect to do any complicated posing anymore? I guess that's true, **i gotta move up to a new Intel mac.
in 2 years i'll be able to get a new comp
Given you're a guy on a budget, your devotion to Apple seems irrational to me.
Let's pick a target price of $800. What can you get for that, say at Best Buy?
From Apple, the only option is the iMac Mini for $799.99.
From PC vendors, there are tons of choices, but let's look at the ASUS Essentio for $779.99 (you save $20).
**CPU: iMac = Intel Core 2 Duo 2 Ghz, ASUS = Intel Core 2 Quad 2.5 Ghz
L2 Cache: iMac = 3 MB, ASUS = 4 MB
Bus speed: iMac = 1066 MHz, ASUS = 1333 MHz
These are your #1 factors in rendering speed, and the ASUS beats the snot out of the iMac. With 4 newer generation cores instead of 2 older ones, and 25% faster on top of that, more cache, and a higher bus speed, you'd easily see a render go 2X faster, and I bet it would actually go 3 to 5 times faster in some situations. That's 5 minute render versus a 25 minute render. I watch a 5 minute render and stop it if I don't like what I see. A 25 minute render, I go away and come back to find I screwed up, and have to wait another half hour to see if I got it right. With renders going 2 to 5X faster, you learn a lot more every day and are a lot less frustrated.
RAM: iMac = 2 GB DDR3, ASUS = 8 GB DDR3
Are you kidding me? 8 GB versus 2 GB is insane! Think about this: Load your base OS and support applications, along with Poser with an empty scene, and you've already used 1 GB of RAM. That leaves 1 GB for scene content (polygons) and rendering on the iMac, versus 7 GB on the ASUS. That's right, you get to play with 7 times as many polygons on the ASUS before it croaks and starts swapping. That's the difference between 10 figures and 70 figures. You want a crowd? Forget that on the Apple - it ain't gonna happen.
Disk: iMac = 320 GB SATA at 5400 rpm, ASUS = 750 GB SATA at 7200 rpm
You need space for content on your disk. Your base used no matter what is 100 GB. For your content, that leaves you with 220 GB versus 650 GB. That's 3 times as much available disk space. Plus, the 5400 rpm drive on the Apple is a slow piece of crap compared to the 7200 rpm disk on the ASUS. So stuff will load 2 to 5 times faster on the ASUS. Do you want to wait 30 seconds or 6 seconds to load a modern high-poly figure with a crapload of morphs?
**GPU: iMac = NVIDIA GeForce 9400M, ASUS = NVIDIA GeForce GT220
VRAM: iMac = 256 MB DDR3 SDRAM, ASUS = 1024 MB GDDR3
This is another blowout victory for the ASUS. The GT220 is bottom of the barrel in PC land, but it still kicks the 9400M in the peanuts. With a faster clock speed, twice as many shader processors, and faster memory that is FOUR TIMES BIGGER, there just is no comparison. You want to pose lots of stuff, or see them in preview with high quality texture rendering or real-time shader preview? Then there simply is no comparison. Not even close.
There are other things we could compare and see the ASUS win, but they're not helpful to 3D. Things like more USB ports, media card readers, etc. The only feature I can find on the iMac equals or exceeds the ASUS is built-in Bluetooth support.
So in summary, the ASUS is 2 to 5 times faster at rendering, holds 7 times more content in a scene, holds 3 times the content on disk, loads that content 2 to 5 times faster, and let's you interact with that content 5 times more smoothly.
These are not little factors, like 25 to 30%, they are 300%, 500%, 700% factors.
If you love your Mac software, then keep the one you have now plugged in, but run your 3D stuff on a PC. Or, be insane. Whichever you prefer.
ok, i'm not even making my populated scene yet. i have an empty scene and i add 1 DAZ character with clothes, 1 james with clothes, and one Daz MATT with clothes and no shoes.
As soon as i add 1 shoe for matt( kid), i start getting message that says
Memory problem.
So imagine a poser environment with a 5 DAZ characters. mmmmm..
is my comcputer just too old, not powerful enough or what?
Macos X 10.4.11, 1.8GZh G5. 2GB RAM
i thought i just needed to restart, and i did but problem continues so that means it's really the fact that more than 3 characters is impossible for my computer
