Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 28 2:24 pm)
Morphs pack for V4 must go into the same Runtime as V4 (so that the initialisation script will work).
The simplest solution is to select "DAZ Studio" as the install type and then select the appropriate Runtime directory.
The other solution is to create a fake Poser.exe in some way (any file with the right name will do, the contents are unimportant) in the Runtime you want to install to.
Thank you both very much for your responses. However, I've tried creating a Poser.exe file (just like Superman said) and placed it in my Smith Micro/Poser Pro directory. I still cannot install the morphs. I don't know why, but I don't see a DAZ directory so I can't install it there.
Does anyone have any other ideas? I'm getting really frustrated. Thanks,
Dov
Quote - However, I've tried creating a Poser.exe file (just like Superman said) and placed it in my Smith Micro/Poser Pro directory.
You almost certainly have extensions hidden (this is the Windows default), so your file is really called Poser.exe.txt
Quote - I don't know why, but I don't see a DAZ directory so I can't install it there.
When you run the installer, instead of selecting "Poser" as the install type, select "DAZ Studio", then when it ask for the destination just choose the Poser Runtime where you want to install.
Doing this is the easiest way to get round the check for Poser.exe (exactly the same files are installed AFAIK).
Hi Mr Raptor
Did you untick the Windows folder option "Hide known file extensions"? And did you delete the extra extension (e.g. .txt) on the Poser.exe file? (See nruddock's second post, first paragraph).
This is the usual reason. Or not installing into the same Runtime as your V4.2. The folder you choose in the installation program must be the parent folder of the Runtime you are installing into.
"If I were a shadow, I know I wouldn't like to be half of
what I should be."
Mr Otsuka, the old black tomcat in Kafka on the Shore (Haruki
Murakami)
Hi all,
I've purchased the DAZ3D muscle morphs package for V4 but when I try to install it in my Poser Pro folder I get a message that the morphs must be installed to the same directory as the application executable. I am assuming this means that I need to install to the Poser Pro folder which I am but I still get the error message.
Does anyone have any ideas? I've fiddled with this and left a message for the folks at DAZ3D but if anyone has something for me to try, please do let me know.
Thanks,
Dov
