Wed, Dec 25, 7:23 AM CST
Subject: Editing figure question?
uncle808us ( ) posted Fri, 03 July 2009 at 5:42 PM · edited Wed, 25 December 2024 at 7:05 AM
Mac OS 10.4.11 Poser 7.0.4.220  I would like to edit a figure in poser to remove a bow tie, How do I go about doing this?
MacBook Pro OSX El Capitan Ver 10.11.6
markschum ( ) posted Fri, 03 July 2009 at 6:51 PM
I would go into materials room , and see if the bowtie is a seperate material. If it is then set transparency to 1 , and speciular to black and 0 .
lesbentley ( ) posted Fri, 03 July 2009 at 7:22 PM · edited Fri, 03 July 2009 at 7:28 PM
Rather than editing the mesh, it would be easier to make the bow transparent. In the Material Room, select the "Bow" material, set the Defuse_Value and Specular_Value to zero. Set the Transparency_Value to 1.0, and Transparency_Falloff to 0.0. This will make the bow invisible in the rendered image.
If you also want it invisible in preview, in your Render Settings, Preview tab, set "Transparency Display" to "Actual".
uncle808us ( ) posted Sat, 04 July 2009 at 11:52 AM
Thank you guys this worked fine. Although I would like to find out how to edit a figure. By deleting somethings but saving bones.
pjz99 ( ) posted Sat, 04 July 2009 at 11:57 AM
If the figure has any morph targets built into it, then changing polygon grouping will trash up the morphs.  Not a trivial task, just hide the material unless you don't have any morph targets built into the figure.
My Freebies
uncle808us ( ) posted Sat, 04 July 2009 at 12:00 PM
No there are no morphs.
pjz99 ( ) posted Sat, 04 July 2009 at 12:31 PM
Looking at your models on Turbosquid I suppose you know your way around a modeler - make a backup copy of the base OBJ the figure is loaded from first, then load the base OBJ in your modeler, delete the bow tie, re-save the OBJ.  Depending on how accurately your OBJ importer works, you may have to take extra steps to retain polygon grouping information so that the bones still work.  The UV space that the bow tie took up will of course end up being wasted.
My Freebies
uncle808us ( ) posted Sat, 04 July 2009 at 12:39 PM
Thanks I will give this a shot.
