Sun, Jan 12, 8:07 PM CST
Subject: Purple actifact spots when rendering at above final quality
hobepaintball ( ) posted Mon, 06 July 2009 at 4:55 PM · edited Sun, 12 January 2025 at 5:12 PM
On render quality above Final I get bright purple spots in the screen where the whitest white would be, like in the sea foam in the attached picture. This should be easy to fix in photoshop, but of course I would rather not have to.
chippwalters ( ) posted Mon, 06 July 2009 at 7:08 PM
 Sorry, you're going to have to give us a bit more information, as in what are we looking at? Rock, water, ??
The purple could be reflected from somewhere else, or it could be part of a material, or a clipping issue, but without information about the scene, it's difficult to diagnose.
aquiavic ( ) posted Mon, 06 July 2009 at 8:29 PM
It looks like your satellite tv is getting poor reception, Probably the weather.
hobepaintball ( ) posted Mon, 06 July 2009 at 11:37 PM
That is the surf line on the water in the scene. it only occures above final quality. Preview and final are fine.
bigbraader ( ) posted Tue, 07 July 2009 at 4:22 AM
Check the post-render options, if lensglare is on, turn it off. Also try it without any other post-render effects. You may try rendering with "User Settings" with anti-aliasing set to "crisp".
  • Lars
Vege-Mite ( ) posted Wed, 08 July 2009 at 5:23 PM
Quote - That is the surf line on the water in the scene. it only occures above final quality. Preview and final are fine.
I have experienced exactly the same problem, but never experimented with different render settings. I got rid of it by changing the Atmosphere. This is only a guess, but maybe I used an Atmosphere created in an earlier version of Vue, that is not compatible with Vue 7.4 Inf.
Adriaan Barel (a.k.a. Vege Mite)
"Morality, like art, means drawing a line someplace." -- Oscar Wilde
