Tue, Feb 11, 8:53 AM CST
Subject: Render Size
meltz ( ) posted Wed, 08 July 2009 at 10:42 AM · edited Mon, 27 January 2025 at 4:17 PM
Ok so in your guys and gals opinion, what is the best render size window to capture the whole body but still close enough to be very detailed ?
LaurieA ( ) posted Wed, 08 July 2009 at 11:07 AM
Well, since you can pretty much choose the size of the rendered image, it doesn't much matter. You can make it whatever you like.
IsaoShi ( ) posted Wed, 08 July 2009 at 2:59 PM
I'd like to give you some useful response about what I do myself, but I'm a bit puzzled by your question. You used the phrase "render size window", but do you really just mean "render size"? Or are you actually asking about the size of the Preview / Render window within Poser?
meltz ( ) posted Wed, 08 July 2009 at 4:39 PM
im a little confused myself lol. Whats the difference between render size and preview / render window?
bagginsbill ( ) posted Wed, 08 July 2009 at 5:06 PM
The size of the render can be the same as or different from the size of your preview window.
meltz ( ) posted Wed, 08 July 2009 at 5:10 PM
OK got ya. so whats the best size preview/render window to use to get the whole body of a figure whithout loosing to much detail?  Or is this just a question that can not be answered, due to me being a noobie lol
bagginsbill ( ) posted Wed, 08 July 2009 at 5:28 PM
Well it depends on a lot of things.
* Who's the viewer - you or somebody you have no idea about?
  • Is the viewer going to see this on a web page, or as a standalone document, or printed?
    * If standalone on a screen, is the viewer using software like Picasa to pan/zoom the image?
  • If not zooming, do you want it to fit on the screen in its entirety?
  • If fitting on the screen, how big is the screen, and is it oriented landscape or portrait?
  • Is panning in both directions ok, or just vertically?
See? Can't answer.
meltz ( ) posted Wed, 08 July 2009 at 5:40 PM
LOL that was what was kind of in my head BB, some confusing stuff indeed
LaurieA ( ) posted Wed, 08 July 2009 at 5:44 PM
> Quote - OK got ya. so whats the best size preview/render window to use to get the whole body of a figure whithout loosing to much detail?  Or is this just a question that can not be answered, due to me being a noobie lol
That would all depend on how you've arranged your working space in Poser. I think everyone's prolly a little different. Mine's attached, but yours might be different if you've re-arranged everything.
ockham ( ) posted Wed, 08 July 2009 at 5:53 PM
One important consideration is small details.  If you have lots of repeated
lines such as the threads of cloth or shingles on a roof, a too-small render
will not only lose those details but often distort them.    You'll get false
indications that may look like a larger weave or an irregular pattern of
shingles.   (This is "aliasing".)
No amount of enlarging in postwork will fix this distortion.
When you render "large enough", the details will be honest, and you
can later shrink the picture in Photoshop or Irfan without losing them.
The details may blur some, but they'll still be an accurate pattern.
How large is "large enough"?  You just have to start small and then try
larger until you see the details accurately.
My python page
My ShareCG freebies
IsaoShi ( ) posted Wed, 08 July 2009 at 5:57 PM · edited Wed, 08 July 2009 at 6:01 PM
Agree with LaurieA on this (she beat me to the post, but I'm posting anyway)
I think the most appropriate answer must be: the largest that you can fit into your screen size, leaving space for the tools & palettes around it.
I have a 1680x1050 pixel display for my main screen, and 1280x1024 for my second screen. I use the second screen for the library palette. My document window is a landscape layout 1125x750 pixels.
If I'm working on an image that is not that particular size or aspect ratio (like the test render in the image above) I just change the render dimensions, but I generally keep the document window the same size. If you wanted to, you could easily change the document window size to suit your image, and you can save your commonly used layouts using the UI memory dots.
Not sure if this helps you at all!
(edit) regarding the render itself, I totally agree with what ockham says. The best way to get more detail is to render more pixels!
