Fri, Jan 24, 10:18 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 24 9:54 am)
Subject: Can I make like this character?
smalll ( ) posted Wed, 08 July 2009 at 5:41 AM · edited Thu, 23 January 2025 at 7:49 AM
Hi.
First, My English is poor.
I'm so sorry.
I want to make a character.
You can see red arrow in the image.
It is my goal.
It is join sword and shoulder. (blue arrow)
I think it is very difficult.
I think it can be joined only one part.
Do you have a idea?
pjz99 ( ) posted Wed, 08 July 2009 at 6:39 AM
You want to have a cable that runs between the sword and the character's shoulder?  It sounds to me like you want two figures:
Character without the sword
Sword + cables, with Inverse Kinematics chains for the cables; you can make the parent of the ends of the IK chain to be the character's shoulder, and I think this will work the way you want.
My Freebies
smalll ( ) posted Wed, 08 July 2009 at 6:58 AM
Thank you, Thank you.
Can you tell me more detaily?
I made a model.
You can download it.
http://www.bokgi.net/test/sowrd.zip
Please..... Please...
pjz99 ( ) posted Wed, 08 July 2009 at 7:54 AM
Something like this.
My Freebies
smalll ( ) posted Wed, 08 July 2009 at 9:08 AM
Can you help me more?
I made it again.
Is it right?
You can download it again.
http://www.bokgi.net/test/sword-2.zip
pjz99 ( ) posted Wed, 08 July 2009 at 9:28 AM
Have you taken this to the Setup Room and added bones?
My Freebies
smalll ( ) posted Wed, 08 July 2009 at 9:55 AM
I'm sorry.
I din't do that.
I need to learn.
Can you teach me how can I do it?
I tried. But it is not working.
I tried to 'set parent'  each chains to right hand and right shoulder.
But, the born is belong to man. And Sword is not working.
I don't know.
Can you help me please?
pjz99 ( ) posted Wed, 08 July 2009 at 10:37 AM
You need to learn how to rig a model in Poser and turn it from a prop into a Figure (like your character is a figure).  This is done by adding bones in the Setup Room.  You should try to watch these videos on how to do this, even though they are in English, the whole process is demonstrated on screen.
http://www.youtube.com/watch?v=q8jxSOL_MAM&feature=related 1 of 3
http://www.youtube.com/watch?v=t6f6MXtKlbU&feature=related 2 of 3
http://www.youtube.com/watch?v=Nggl2JSLLtc&feature=related 3 of 3
You are also starting with a fairly advanced project.  You should probably try to start with something simpler, like just a cable.  Once you understand how to rig an easy project, like a simple cable, you can build on that and try to do something harder, like if the cable is connected to another object like your sword.  The last step would be to add Inverse Kinematics - for a straight cable, like what you have, that is not very hard, but the model has to be rigged first.
My Freebies
pjz99 ( ) posted Wed, 08 July 2009 at 10:41 AM
Also, are you able to translate the text in my image above?  I didn't think of that.  My handwriting is not very good.
My Freebies
smalll ( ) posted Wed, 08 July 2009 at 7:02 PM
Thank you pjz99.
I think that I understood the video tutorial. (Maybe....)
Do you think there is any problem in my figure(sword)?
I don't know where is the problem.
Can you tell me more?
http://www.bokgi.net/test/sword-3.zip
And I offer you my heartfelt thanks for your favor.
chriscox ( ) posted Wed, 08 July 2009 at 9:05 PM · edited Wed, 08 July 2009 at 9:06 PM
It looks like you have the "sword" as a child to "chain01". I think it will work much better if you have "sword" first and the rest of the body parts after it. I'll take a look at the file you have and see if there is anything else that could be changed.
Chris Cox
smalll ( ) posted Wed, 08 July 2009 at 9:23 PM
Thank you Mr. **chriscox.
I modified it.
http://www.bokgi.net/test/sword-4.zip
chriscox ( ) posted Wed, 08 July 2009 at 11:36 PM
I took a quick look at your sword and did not see any problems.  I would suggest that you have the chain straight like you had in version 3 instead of bent like it is in you last version, 4.  It will make posing the chain easier. Your next step would be to add the IK chain using the Hierarchy editor.
Chris Cox
smalll ( ) posted Wed, 08 July 2009 at 11:59 PM
Thank you!
I tried.
But, I don't know how can I link to right shoulder.
Can you help me more please?
chriscox ( ) posted Thu, 09 July 2009 at 12:11 AM · edited Thu, 09 July 2009 at 12:13 AM
You can turn on you IK chain by going to Figure on the main menu choosing Use Inverse Kinematics and then selecting the IK chain.
After that you can position Chain10 where you want it.
Finally you can parent Chain10 to the man's arm so when the man's arm is moved the chain will be dragged along.
Chris Cox
smalll ( ) posted Thu, 09 July 2009 at 12:16 AM
You are right!
I did it!
 I´d like to express my heartfelt thanks to you.
Thank you!!!!
chriscox ( ) posted Thu, 09 July 2009 at 12:21 AM
Glad to hear it.  Now I can go to sleep 8^)
Chris Cox
pjz99 ( ) posted Thu, 09 July 2009 at 4:15 AM
Oh I just woke up.  Well, glad it is all solved :)  Thanks Chris that was very helpful.
My Freebies
