Tue, Oct 22, 6:51 AM CDT
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 22 6:50 am)
Subject: Help please, alphabetical reversed when trying to open files
lululee ( ) posted Fri, 10 July 2009 at 10:03 AM · edited Tue, 22 October 2024 at 6:50 AM
Hi, When I try to open files the alphabetical order is reversed. Grrrrrrrr! It is doing my head in constantly thinking backwords.   Is there a cure for this? I am running Windows XP PRO 64bit. Must return to sanity. cheerio lululee
markschum ( ) posted Fri, 10 July 2009 at 10:20 AM
You probably have set that folder view . In windows explorer go to that folder and select view by name .
FalseBogus ( ) posted Fri, 10 July 2009 at 10:21 AM
Tried right clicking in the prompt and choosing from menu different sorting order?
geep ( ) posted Fri, 10 July 2009 at 10:35 AM · edited Fri, 10 July 2009 at 10:40 AM
Try this:
(right) CLICK "Start" button (lower left corner of screen)
CLICK  "Explore"
[menu] View >>> "Details"
Click on >>>  "Name"
Don't like the order? :blink:  ... Click on "Name" again to reverse it. 😄
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
lululee ( ) posted Fri, 10 July 2009 at 10:38 AM
Still No win.
I can change the view at the prompt, but it reverts to the reverse next time i try to open a file.
I have changed all the drive folders to the correct order but it still reverts.
Boohoo.
lululee
geep ( ) posted Fri, 10 July 2009 at 10:40 AM
Try this:
CLICK  "Explore"
Click on >>>  "Name"
Don't like the order?   ... Click on "Name" again to reverse it.
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
lululee ( ) posted Fri, 10 July 2009 at 11:05 AM
This is too bizare. I have changed them in the menu "view".
It only occurs wehn I try to open a file. if I just look at the file structure the order is correct.
When opening a file, I can right click and reverse the order, but it does not hold for the next time.
Grrrrr!
cheerio
lululee
chriscox ( ) posted Fri, 10 July 2009 at 11:20 AM · edited Fri, 10 July 2009 at 11:20 AM
Attached Link: File sort order reversed
I found this which might help [ http://www.technologyquestions.com/technology/windows-xp/15828-file-sort-order-reversed-wrong-file-open-file-save-dialog-box.html](http://www.technologyquestions.com/technology/windows-xp/15828-file-sort-order-reversed-wrong-file-open-file-save-dialog-box.html)
Chris Cox
lululee ( ) posted Fri, 10 July 2009 at 11:25 AM
Hi Chris,
Bless you my child! What a relief. It worked like a charm.
Thank you for saving my sanity and squashing the cockroach.
cheerio
lululee
Porthos ( ) posted Fri, 10 July 2009 at 1:14 PM
Strange that my files started listing in reverse also, I don't recall changing anything! Thanks for the fix chriscox! :)
MS Windows 7 Home Premium 64-bit SP1
Intel Core i7-2600 CPU @ 3.40GHz, 12.0GB RAM, AMD Radeon HD 7770
PoserPro 2012 (SR1) - Units: Metres , Corel PSP X4 and PSE 9
