Mon, Dec 23, 6:14 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 23 1:20 pm)
Subject: white line between butt checks
morphious ( ) posted Wed, 15 July 2009 at 5:52 PM · edited Mon, 23 December 2024 at 12:07 PM
I know this is a newbie question, but didn't turn up anything in the search. How do you get rid of tht white line between V4's butt cheecks, or any poser figure for that matter? Thanks for your help.
hborre ( ) posted Wed, 15 July 2009 at 6:08 PM
Are you using raytracing in your render?  And you did mean cheeks, not checks?
IsaoShi ( ) posted Wed, 15 July 2009 at 6:11 PM · edited Wed, 15 July 2009 at 6:12 PM
I think you are using AO on a light - ? - and this is related to the scene AO bias setting.
Open the Properties palette of the light with AO switched on, click into the Scene AO options, and reduce the bias value. Start with around 0.05 inches (you will need to convert that to whatever Display Units you are using, if you are not using inches) and take it as low as you can until you start to see black artifacts on the figure's skin, then increase it a bit to get rid of those artifacts.
That should hopefully sort this out for you.
(edit) hborre - yes RT is on, otherwise there would be no AO
morphious ( ) posted Wed, 15 July 2009 at 6:14 PM
yes, using AO light. I'll try your suggestion. Thanks.
hborre ( ) posted Wed, 15 July 2009 at 6:19 PM
Yep, you're right.  Didn't notice it straight off.  Usually that part of the anatomy can put a person off.
geep ( ) posted Wed, 15 July 2009 at 6:33 PM · edited Wed, 15 July 2009 at 6:36 PM
JIC 😄
cheers,
dr geep ... :o]
edited 10/5/2019
