Sat, Feb 1, 10:06 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 01 9:18 am)
Subject: a bit of a problem...
Wild_Dog ( ) posted Tue, 17 July 2007 at 5:20 PM · edited Sun, 26 January 2025 at 6:52 PM
Ok, I downloaded Play with Poser's Miyu P4 compatible character. the problem is that I need a P4 woman OBJ file. my problem is that I don't have a obj file, but one that is a OBZ. file. I upload the P4 Fem model no problem in P6, but there is no P4woman obj file. can someone help me.
Miss Nancy ( ) posted Tue, 17 July 2007 at 5:26 PM
unzip the obz file.
SYNTRIFID ( ) posted Tue, 17 July 2007 at 5:27 PM
Load the P4 woman into Poser in the normal fashion, Export it to obj. Save the obj in a folder your character can reference as needed.
Hey! His nose is dry! ... Someone should lick it,  just in case. - Diego
kuroyume0161 ( ) posted Tue, 17 July 2007 at 5:44 PM
Unzipping the obz file is much more expedient.  Also, you'd better mention doing Zero Figure before export or things will get strange.  Figures don't load in zero pose, they load in a memorized pose - usually to aid IK calculations.
 -- Bjarne Stroustrup
SYNTRIFID ( ) posted Tue, 17 July 2007 at 5:51 PM
Quote -   Figures don't load in zero pose, they load in a memorized pose - usually to aid IK calculations.
True, I did neglect to mention the details..
Wild_Dog ( ) posted Wed, 18 July 2007 at 9:15 AM
Quote - unzip the obz file.
with what do I unzip it with? it just says that its a OBZ file, no WinRar or anything.
kuroyume0161 ( ) posted Wed, 18 July 2007 at 10:43 AM
Open WinZip and drop the .obz file onto it.  Then you extract the .obj file from there (you can drag-n-drop the .obj file in WinZip out onto Explorer to do this).
infinity10 ( ) posted Thu, 19 July 2007 at 9:04 PM
Online Now!
If you have Poser 6 or Poser 7, there is a Python option you can execute to uncompress the file - best copy it in an external folder far away from your Poser 7 runtime, and process the unzipping  there.
Eternal Hobbyist
JAG ( ) posted Sat, 18 July 2009 at 8:20 PM
Winzip does NOT open OBZ files.  I have tried this with several programs for unzipping and compression.  I'm not sure how you got it to work but the file format is not recognized even by the newest version of the software mentioned.
chriscox ( ) posted Sat, 18 July 2009 at 9:22 PM · edited Sat, 18 July 2009 at 9:22 PM
Quote - Winzip does NOT open OBZ files.
I does for me.
I did just what kuroyume0161 said and it worked perfectly.
That was using WinZip 10.
Chris Cox
chriscox ( ) posted Sat, 18 July 2009 at 9:25 PM
Something else you can try is to change the file extension from .OBZ to .GZ and then try to uncompress the file.
Chris Cox
chriscox ( ) posted Sat, 18 July 2009 at 9:29 PM
Also, there is a Python script to uncompress files, "uncompressPoserFiles".  It may be under utilities in the Scripts menu.
Chris Cox
hborre ( ) posted Sat, 18 July 2009 at 10:50 PM
OBZ opens fine in Winrar.
MistyLaraCarrara ( ) posted Tue, 21 July 2009 at 12:35 PM
Is Winrar a free utility somewhere?
I have a .rar file of PS brushes I don't understand how to install.  I thought it was a unix file extension or something.  silly, eh?
sixus1 ( ) posted Tue, 21 July 2009 at 12:48 PM
Attached Link: http://www.7-zip.org/
I've used 7-Zip to uncompress obz files
lmckenzie ( ) posted Tue, 21 July 2009 at 1:28 PM
 "Is Winrar a free utility somewhere?"
Not free but the demo will probably work or "Universal Extractor (http://www.legroom.net/software/uniextract) free should work as well.
hborre ( ) posted Tue, 21 July 2009 at 1:38 PM
There is an evaluation copy of Winrar available.
