Sat, Jan 25, 3:24 AM CST
Subject: Hdrvfx (of the Albany nights lightset) their website has an IBL download pack
MistyLaraCarrara ( ) posted Thu, 23 July 2009 at 11:27 AM · edited Thu, 23 January 2025 at 1:30 AM
www.hdrvfx.com/index.html
They have an IBL library for Download on their resource page. (140mb)
I'm itching to try 'em out, but I have to wait til I get to my home PC.
It's a touch subject, creating HDRI images.
I have a few beach and nature photos,
if someone would like to convert them somehow to HDRI or IBL lights,
be willing to share 'em with the community!
Cheers,
Khai-J-Bach ( ) posted Thu, 23 July 2009 at 11:29 AM
thanks :) nabbed 'em
MistyLaraCarrara ( ) posted Thu, 23 July 2009 at 11:36 AM
Quote - thanks :) nabbed 'em
cool!  Show a render, eh?!
The jaypeg for nyany looks good from here.
Sa_raneth ( ) posted Thu, 23 July 2009 at 12:33 PM
got it thank you
MistyLaraCarrara ( ) posted Fri, 24 July 2009 at 12:47 PM
Does anyone know where to plug in the 2nd .hdr file?
thanks.
I'm really appreciating the IBL Wacro.  It's trial and error to get the best intensity setting.
MistyLaraCarrara ( ) posted Fri, 24 July 2009 at 12:51 PM
Here's a sample render with  'chanc'.
It looks like early morning light.  That's the brown messy hair in the scene.
jartz ( ) posted Fri, 24 July 2009 at 12:58 PM · edited Fri, 24 July 2009 at 12:59 PM
Thank you so much for the info.  Is it the HDRI Sample Library 140MB under Resources?
Asus N50-600 - Intel Core i5-8400 CPU @ 2.80GHz · Windows 10 Home/11 upgrade 64-bit · 16GB DDR4 RAM · 1TB SSD and 1TB HDD; Graphics: NVIDIA Geforce GTX 1060 - 6GB GDDR5 VRAM; Software: Poser Pro 11x
MistyLaraCarrara ( ) posted Fri, 24 July 2009 at 1:09 PM · edited Fri, 24 July 2009 at 1:10 PM
Quote - Thank you so much for the info.  Is it the HDRI Sample Library 140MB under Resources?
Yes.   It doesn't come with any Poser ready .lt files or pngs thumbnails.
I manually copied the files to the same Texture folder with albany nights.
Used the IBL wacro to start setting up material files.  The default intensity needs adjusting.
There isn't a specific Wacro for HDR node setup.  Unless someone made one? hint hint
But, the renders are coming out spiffy, so i think it's worth the hassle.
MistyLaraCarrara ( ) posted Fri, 24 July 2009 at 2:41 PM
According to this page:  http://www.hdrlabs.com/sibl/loader.html
the env 's are a preset for something called Modo.
I get the feeling these guys don't take Poser as a rendering program seriously. lol
jartz ( ) posted Fri, 24 July 2009 at 3:16 PM
Hopefully with Poser 8 [fingers crossed], it might change things.
Thanks so much for the heads up.
hborre ( ) posted Fri, 24 July 2009 at 7:43 PM · edited Fri, 24 July 2009 at 7:44 PM
The .hdr is plugged into the color_value of your light node in the Material Room.  Contrast should be set to 1 and intensity reduce according to how the .hdr was prepared.  It is is dark or a night scene then the intensity will be high. On the light end, the intensity will be low.  Remember. the hdr is just providing an ambient light source, there will be no shadows and specularity cast.  Infinite and spot lighting should be introduced separately.  The .jpg image can be used as a background image although it is a panorama of a scene.  If you have HDRShop, those scenes can be converted to lightprobes for Poser 7.  The scenes can also be used in bagginsbill's envsphere although that prop in essence requires equirectangular panoramas.  For single plane use, load the image into a one-sided square, set your scale x and y to the exact pixel dimension of the image and then scale the prop to whatever size you desire for a background.
I use IBL all the time to give my scenes a more realistic kick.
