Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 22 3:39 am)
Create a copy of the original .cr2 file.
Open the copy .cr2 in a text editor, I use Notepad ++, change forceLimits 0 to forceLimits 1 and save the file.
Test this revised .cr2 in Poser, the limits applied to the parameter dials should now be recognized.
If everything works properly replace the original .cr2 file with the revised edition. I keep the original in an archive just to be on the safe side.
There is some discussion on the non-zero value to use (1-4) but I haven't noticed it making a difference so I just change it to 1, nothing has exploded......yet.
I'm pretty sure the 1 versus 4 difference was an urban legend, or possibly
true for some unusual circumstance. I confess to helping spread the myth,
because I thought I saw the difference.
As far as I can tell (tested carefully in both P4 and P7 right now) the value 1 will
always force the limits regardless of the setting of Figure: Use Limits.
More precisely, when forceLimits is 0, the figure:UseLimits setting matters.
When forceLimits has a*ny nonzero value, *the limits are solid. So 4 won't
make anything explode, but it's no different from 1.
My python page
My ShareCG freebies
Ironically DAZ studio will recognize the force limits set on a parameter dial in Poser figures without having to edit the .cr2.....bringing us to: WTF are Poser devs thinking?
Astoundingly blind to require manual editing to activate a parameter value that was set within the native application originally.
Well, thank you very much for these precious advices guys !
visit my
blog: www.alessandromastronardi.com
My
Rendo Store
You can also use a pose file to force limits, eg: {
version
number 3.0
actor head
channels
targetGeom RoundFace
forceLimits 1
The pose can also set the 'min' and 'max' value of the limits, eg: {
version
number 3.0
actor head
channels
rotateY yrot
forceLimits 1
min -35
max 35
For P5 and up, you can also make a generic pose file that will force limits on the selected actor, by using "actor $CURRENT", eg: {
version
number 5
actor $CURRENT
channels
targetGeom PBMCC_04
forceLimits 1
min -0
max 1
rotateX xrot
forceLimits 1
rotateY yrot
forceLimits 1
rotateZ zrot
forceLimits 1
Hi, any way to trigger the figure option "Use Limits" alway on for a certain character or pose, so that the user doesn't have to go through the menu and trigger it manually ? Thanks
visit my blog: www.alessandromastronardi.com
My Rendo Store
