Fri, Jan 31, 4:57 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 31 3:43 am)
Subject: Half of object does not show up after import
Crescent ( ) posted Sun, 15 July 2001 at 2:41 PM ยท edited Fri, 31 January 2025 at 4:46 AM
I created a belt for Vicki in Rhino 2.0 but when I imported it (after UV Mapping it) only the back half shows. It renders just fine but it would be nice to see all of it when not rendered. I tried using the Grouping tool to flip individual polygons, but that did not help. Rhino shows the UVs facing the correct way. Any suggestions?
doozy ( ) posted Sun, 15 July 2001 at 3:32 PM
try checking "make normals consistent" when you import.
smerc ( ) posted Sun, 15 July 2001 at 4:10 PM
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=343118
Check out reply #7 You need to check your normals before exporting to Poser. smerc
steveshanks ( ) posted Sun, 15 July 2001 at 4:15 PM
Do you have a back face culling switch in rhino?? i ge this all the time in cinema and switch BFC on to check them ..Steve
Xurge ( ) posted Sun, 15 July 2001 at 6:04 PM
In Rhino before export, check the surface direction, if the arrows point inwards, type flip and hit enter. then make the mesh and export. This will correct the direction of the surface. The image highlights the direction arrows and the tool button for it.
