Sun, Jan 12, 11:53 AM CST
Subject: Trouble loading .obj
uncle808us ( ) posted Fri, 31 July 2009 at 9:23 AM · edited Sun, 12 January 2025 at 11:48 AM
When I load a wavefront object I get a little box with an X in it in front of the object name. And I can't see the object. But it imports and the name is there in the layer window. Any idea what the x in the box means? Thanks.
MacBook Pro OSX El Capitan Ver 10.11.6
Mazak ( ) posted Fri, 31 July 2009 at 9:49 AM · edited Fri, 31 July 2009 at 9:51 AM
Your object is hidden. Click with the mouse on the X and you will see the object again.
Mazak
Google+ Bodo Nittel
uncle808us ( ) posted Fri, 31 July 2009 at 9:57 AM
Quote - Your object is hidden. Click with the mouse on the X and you will see the object again.
Mazak
Did that still no oblect and the X remains there.
Mazak ( ) posted Fri, 31 July 2009 at 10:09 AM
That is really odd :( I get as tool-tip Hide from render.
Mazak
Google+ Bodo Nittel
Mazak ( ) posted Fri, 31 July 2009 at 10:12 AM
Can you import your obj in an other application? Maybe the file is corrupt and need re-save.
Mazak
Google+ Bodo Nittel
uncle808us ( ) posted Fri, 31 July 2009 at 10:26 AM
Quote - Can you import your obj in an other application? Maybe the file is corrupt and need re-save.
Mazak
That was the problem.
ShawnDriscoll ( ) posted Sat, 01 August 2009 at 4:03 AM
Also watch out for n-gons in your OBJ models.  Vue will abort importing if there are enough of them.  Groupings from Lightwave OBJ exports will hiccup Vue too.
uncle808us ( ) posted Sat, 01 August 2009 at 10:27 AM · edited Sat, 01 August 2009 at 10:28 AM
Good tip thanks. I try for all triangles.
