Attached Link: http://www.e-onsoftware.com/resources/ShowUpdates.php?ProductTypeID=79
Here:http://www.e-onsoftware.com/resources/ShowUpdates.php?ProductTypeID=79
Mazak
Here what EEF update describes:
Your Maintenance Plan for Vue 7.5 Infinite includes access to free Expedited Engineering Fixes (EEF).
Warning: EEF updates have not undergone the full scope of e-on software update validation. They are provided to you in an attempt to help resolve as quickly as possible any blocking issues you may experience with our software.
It is recommended that you only install EEF updates if one of the issues addressed by the EEF is blocking for you.
Mazak
no, that means you only get the EEF if you have a maintenance plan. Once it goes through the normal bugfix testing then I'd imagine it would be released as normal. The maintenance plan just means you get it a bit earlier and with a bit less testing
My Freebies
Buy stuff on RedBubble
Maintenance people get Alpha tests to try before us regulars get the usual Beta update. So far, no Beta is available. If you are having a work stopage with 7.5, you can submit a bug report to the technicians and they will email you a link for you to download a patch if they know of the problem already and that it will fix your situation.
I don't happen to have a major problem right now to email them about. I'm using build 43360. I'm glad to know they are still working on 7.5. But with fewer users out there using the latest build, there are not a lot of testers for E-on to get feedback from for bug fixes. If they'd just release a beta for everyone to use, they'd get more (or less) bug reports so they could work on those.
But their business plan is a different beast now.
Does anyone here know if build 44720 fixes the annoying file not found when importing a Poser figure? I've been hitting cancel each time but the figures seem to load ok anyway.
In Poser 6 save a figure (James) and then open Vue Inf 7.5 and import PZ3 file. Error message is displayed. Both apps are installed in their default paths for Windows XP SP3.
Mazak
Quote - I never use the original Poser figures, I only use Daz ones (V4, M3, H3, A3) and these work beautifully. I will try with original figures.
Do you also have problems with Daz figures?
DAZ imports, which use the 'Elite Series' of add-ons, show the same problem, Vue complains that file 'blabla_whatever.jpg' (with complete path) could not be found. Of course the path and filename are both valid, and Vue has the permissions to read that file.
Annoying as hell...
Mazak
I don't have DAZ Studio. Just Poser 6 for Windows with the last e-Frontier service release.
Still waiting for the new build to be posted. E-on's "webmaster" is asleep at the wheel.
Lucky you. But for everyone else that doesn't have Engineering Fix access, the beta was finally posted a couple hours ago.
Quote - Lucky you. But for everyone else that doesn't have Engineering Fix access, the beta was finally posted a couple hours ago.
From your statement I assume that we seem to have different license models, however I didn't yet sign any maintenance plans.
Maybe it's because I purchased it just a couple of weekes ago...
Tom
Quote - Does anyone here know if build 44720 fixes the annoying file not found when importing a Poser figure? I've been hitting cancel each time but the figures seem to load ok anyway.
It does not. But Build 44720 did fix a lot of other problems I was having, like texture image bump maps not using the correct shading and highlights. That was a major pain for years.
New EEF Build 44720 is online. I download atm Poser8 so I didn't have time to test the new build.
Mazak
Vue 7.5 Infinite - Build 44720 The following is a list of bug fixes and improvements included in this update:
Google+ Bodo Nittel
