Carrara F.A.Q (Last Updated: 2025 Jan 11 8:46 pm)
Funky. The installer should put it in the correct location unless you've chosen a different location to install Carrara. You may want to confirm the install location.
Also, if you've located the Content in another directory, you can use the little document icon in the upper right corner of the Browser and link to it.
I have Carrara 6.2 and in it there are objects lots of them. But I also have Carrara 7 standard. in it there are leaves only. Where are all the objects?
I am pretty sure I have downloaded all the Carrara 7 standard files.
Thanks for the help in advance.
MacBook Pro OSX El Capitan Ver 10.11.6
