Fri, Dec 27, 8:06 AM CST
Subject: Vue + Poser 8 + external runtimes = problem?
andromedakun ( ) posted Fri, 14 August 2009 at 2:58 AM · edited Fri, 27 December 2024 at 8:02 AM
Hello there ;)
I have Poser 8 freshly installed (comming from Poser 6) and seem to run in a bit of problem with external runtimes while importing in Vue complete.
Most of my runtime is located in:
C:program files (x86)e-frontierposer 6runtime
but some of my new runtimes (and all of them in the future) will be located under:
d:runtimes
At the moment, in "d:runtimes", there are 2 sub runtimes (cookie and scenes).
When I used Poser 6, I could import Cookie with no problem into Vue. Just by saving the pz3 and importing in vue, it would find everything back.
Now, I tried the same in Poser 8 and Vue couldn't find Cookie anymore ( or any other thing outside of the "c:program files (x86)e-frontierposer 6runtime" folder.
Anyone know if there is some trick to solve this?
Many thanks,
Andro
SAMS3D ( ) posted Fri, 14 August 2009 at 3:28 AM
 Yes, the same happened to me, I posted it in the p8 forum, maybe they will put fix in Vue or P8.  Sharen
andromedakun ( ) posted Fri, 14 August 2009 at 3:48 AM
Thanks ;)
So no sollution yet then? I'll continue to use P6 to import into Vue then ^^
Andro
Mazak ( ) posted Fri, 14 August 2009 at 4:12 AM
You can have external runtimes, but they must be on same drive to work.
For example:
D:program filese-frontierposer 6runtime
D:program filessmith microposer 7runtime
D:program filessmith microposer 8runtime
This problem is known since P7 but was never fixed. Another workaround is merge all runtimes to a big one. (that was I did)
Mazak
Google+ Bodo Nittel
andromedakun ( ) posted Fri, 14 August 2009 at 4:21 AM
Ok, so if I move all the runtimes to d:runtimes, I would have no problem anymore...
I'll see if I can get all the content installed in those runtimes again...
Vege-Mite ( ) posted Sat, 15 August 2009 at 11:10 AM
I had the same problem and purchased "CR Pro" and edited all my external Runtimes to show "Full Path" and not "Relative Path", which is the default and what most content creators use.
Adriaan Barel (a.k.a. Vege Mite)
"Morality, like art, means drawing a line someplace." -- Oscar Wilde
Vege-Mite ( ) posted Sat, 15 August 2009 at 11:20 AM
Quote - You can have external runtimes, but they must be on same drive to work.
For that to work you'd have to install the Poser application on your "D" drive too, along with the Runtime.
