can you post an image of this prop/figure? Do you have an image similar to what you are trying to achieve?
Poserverse The New Home
for NYGUY's Freebies
**@ camthaleon
Select a sub-group of polygons and then click >>> "Create Prop" ...
to make a new prop.
The "New Prop" is created in exactly the same location as the original so ...
Move the New Prop to see what it looks like.
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
Now ... if you want to make the Original figure (prop) change to the new (prop with missing pieces) ...
Try doing this ...
Make sure both objects are in exactly the same location ...*
Now use the (animated) transparency parameters of both objects to switch between them giving the appearance of the original being partially destroyed.
Pretty cool beans, no? :biggrin:
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
I have a planet or moon rather kind of figure. It's basically a circular shape. Is it possible in any way to extrude it? I would like to make it deformed, or even partially destroyed like in "Time Machine", is it possible in Poser?
