Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 20 11:41 am)
Heehee. Never thought of that. I'll do that and see what it looks like.
I want it, because I tinkered and tinkered with settings that were originally based on the AO version of VSS. I didn't think of saving the VSS prop rather than an MC on the figure, so it got detached. It's a convoluted story, but ultimately, what it boils down to is that I want to re-create a very close approximation of what I've got with a new iteration of the non-AO version of VSS, so I need to have a good look at the info that I can print out. Too easy to get lost with a visual method of comparing on the monitor, and anyway I don't have dual monitors at the moment.
______________
There is ALL in the list of materials , which will list all materials,. Selecting a material will list only it.
Materials are from selected figure only at this stage. Requires Poser 7 for the dialog.
Thanks so much for your work on this. I just printed it off (7 pages).
The ability to print directly isn't all that crucial, as it's no trouble to copy and paste into a new doc.
Nice work!
______________
This prompts for what material you want , or ALL, and then prompts for the location and name of the save file. The heading is wrong on the save file screen but no way to change it .
The file is formatted text , and should view and print correctly from Wordpad.
There are all sorts of Python scripts listing things like content in a scene blah blah (see e.g. the Scripts > Print Info menu in P8).
Is there a script that will print material settings? a bit more complex, I suppose....
______________
