Tue, Feb 11, 1:52 AM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2025 Feb 10 2:42 pm)
Carrara Free Stuff here.
Subject: I need an advice about the tweeners:-((
Bryghtness ( ) posted Sun, 15 July 2001 at 8:05 PM · edited Tue, 11 February 2025 at 1:45 AM
I want to rotate an object around its axis more than 360 degrees (4-5 revolutions per second) with applied motion tweener. The aim: in the beginning it rotates slowly, then faster, and then slowly again (see the tweener pic). Problems: 1. I can't tell Carrara to rotate my object several times around its axis. It says that the rotating value must be between -180 and +180 degr. Arghhh! Even Bryce allows that! 2. I tried to use a modifier (spin). Now the tube rotates as I wanted, but the tweener cannot be applied - the object rotates with constant speed. Any help will be appreciated. 10x in advance!
AzChip ( ) posted Mon, 16 July 2001 at 10:30 AM
I've had this problem in RDS. Here's what I did. I rotated the object manually, and yes you can only rotate it 180 degrees AT A TIME. So, I had an object I wanted to rotate four times; I started it at yaw=0. Then moved to 1 second, rotated it 179 deg. Then moved to 2 seconds, rotated it 179 deg, again (using local coordinates, not global). I applied the bezier tweener because I was increasing the speed (or actually, reducing the time between 179 degree rotation keyframes). Kind of a sucky work around, but it did the job for me. Hope this helps!
litst ( ) posted Mon, 16 July 2001 at 11:12 AM
Hi Bryghtness, There is a way to do this very simply with Carrara . You want to animate the speed your object spins ? Well, just animate the speed your object spins ! ;) - first, add a spin modifier to your object . Set the cycles per second to the speed you need for the beginning of your anim . - move the "timeline" to the end of your anim ( 5 sec on the images ) . Set the cycles per second to the speed you need for the end of your anim . Carrara automatically creates a keyframe . Have a look of what the characteristics of your object should like when you extend its tree in the sequencer . Of course, you can add as many keyframes as you like if you need some more complex speed modifications . Hope it helps ! litst
brenthomer ( ) posted Mon, 16 July 2001 at 1:52 PM
HAHAHA...I was banging my head about this. Last year I just gave up on it. I hate it when simple things hold you back :)
Bryghtness ( ) posted Tue, 17 July 2001 at 2:29 AM
merci, litst (my French ends here ;-)) I convinced myself again that this forum is the best place for Carrara-related stuff. greetz2all!
