Sun, Jan 12, 2:05 PM CST
Subject: getting lots of texture error messages in poser 8
estherau ( ) posted Mon, 17 August 2009 at 4:38 AM · edited Thu, 08 August 2024 at 9:12 PM
 even when I restart.  this didn't happen when I first started doing things in poser 8, but now it's all the time making it impossible to use.
Is there any solution/
Love esther
MY ONLINE COMIC IS NOW LIVE
estherau ( ) posted Mon, 17 August 2009 at 5:56 AM
 Just examined my pz3 in a texure editor - you will never believe this!
":Kimberly:Runtime:Textures:outoftouch:kimberley_hr:06KimbCap.jpg"
I have no directory called kimberly
the runtime is in a folder called Poser_Hair_Kimberly
poser 8  has made up a folder name!
Love esther
PS I deleted the hair and put it on again and resaved but same path
estherau ( ) posted Mon, 17 August 2009 at 6:02 AM
 but chanign that witha text editor didn't help.
I tried changing Textures to textures as this was how it was really but that didn't help either.
I don't know but the paths sure are funny.  I would have thought deep search would find it all anyway.  Poser 7 opens it fine even with funny path.
Love esther
smee440 ( ) posted Mon, 17 August 2009 at 6:12 AM
I am having this problem too and as you say it makes Poser 8 unusable. Sometimes it finds textures but more often than not it doesn't.
I have deep search set and have checked the .cr2/pz2 files and all of the paths are relative. Not sure if it has anything to do with it but I am on Vista 64-bit with UAC turned off.
One thing you can do, once you have located all of the textures that Poser 8 can't find, is use the python script 'collectSceneInventory' (Scripts > Utility) to save the scene and all of the textures that it uses in a folder. Next time you can open the scene from there without 'can't find texture' errors. Too much work for me though.
I have now given up with Poser 8 and am sticking with Poser Pro where textures from the same external runtimes load fine. I hope this isn't going to be an issue in Poser Pro 2010?
[url=http://holocrash.smackjeeves.com][img]http://img1.smackjeeves.com/images/uploaded/banners/8/6/86a8be6572n9H.jpg[/img][/url]
estherau ( ) posted Mon, 17 August 2009 at 6:19 AM
 Hi there,
well I really liked the new lighting and the speediness of my python scripts in poser 8 however I too will have to revert back to poserpro as your fix is too much work for the things I am trying to do.
I am on mac by the way so it is not quite related to the computer I don't think.
Everything worked fine when I first started using poser 8 though but not now.
Love esther
smee440 ( ) posted Mon, 17 August 2009 at 6:57 AM
Well this is really annoying!
I thought I had better do the right thing and raise an incident at SM about this so I opened up Poser 8 to get the correct error message and what do you know - every texture loaded fine - no errors at all!
It is only temporary though, I know from past experience that it works sometimes and then breaks again. It is just playing with me!
I'd rather it didn't work at all than work when it feels like it. At least that would make tracking down the cause easier.
estherau ( ) posted Mon, 17 August 2009 at 7:03 AM
 Maybe it will keep working properly for you now?
Good luck
Love esther
Vege-Mite ( ) posted Mon, 17 August 2009 at 7:10 AM
I have this problem too and I think you will find others are also. I'm sure Smith Micro are aware of the problem and will release a patch.
To cut this problem down to a minimum, I used CR Pro. and changed all my paths from relative to full. I now only occasionally get an error message, but the 'Mat' or materials load fine in spite of it.
Most of my content are in external Runtimes in a separate Partition on my Hard Drive.
Adriaan Barel (a.k.a. Vege Mite)
"Morality, like art, means drawing a line someplace." -- Oscar Wilde
ockham ( ) posted Mon, 17 August 2009 at 7:15 AM
P7 sometimes has a problem with underscores in file names.  Looks like it was carried over
to the new version.
My python page
My ShareCG freebies
estherau ( ) posted Mon, 17 August 2009 at 8:39 AM
 I have underscores in my folders that I keep my external runtimes in.
Love esther
hborre ( ) posted Mon, 17 August 2009 at 9:18 AM
I've noticed that if the runtime is not defined in the P8 library palette, it arbitrarily starts to search for textures files.  This had happened to me twice.  Once the runtime is loaded the problem is corrected.  At least, this has happened for me.
AnAardvark ( ) posted Mon, 17 August 2009 at 9:20 AM
I've had this problem too -- it decides that texture files in an external runtime are actually in the main Poser 8 runtime. (Note: I used the install option which uses the traditional location for the runtime.)
I keep having crashes after it doesn't find textures in scenes which open fine in Poser 7.
markschum ( ) posted Mon, 17 August 2009 at 10:10 AM
I would rename any folder in runtime that uses the underscore or spaces in the name.
AnAardvark ( ) posted Mon, 17 August 2009 at 10:15 AM
Quote - I've had this problem too -- it decides that texture files in an external runtime are actually in the main Poser 8 runtime. (Note: I used the install option which uses the traditional location for the runtime.)
Oddly enough, it actually ends up listing two copies of the texture -- one from the correct place, one from the incorrect.
estherau ( ) posted Mon, 17 August 2009 at 5:44 PM
 "I would rename any folder in runtime that uses the underscore or spaces in the name. "
not ifI want all my old PZ3s etc to still work
PilotHigh ( ) posted Mon, 17 August 2009 at 9:05 PM
Quote - > Quote - I've had this problem too -- it decides that texture files in an external runtime are actually in the main Poser 8 runtime. (Note: I used the install option which uses the traditional location for the runtime.)
I'm on a Mac and this is happening to me as well. Two copies of all the textures!
