Sat, Jan 11, 6:38 PM CST
Subject: Shiny Floors
TimKiver ( ) posted Mon, 17 August 2009 at 1:55 PM · edited Fri, 10 January 2025 at 6:20 PM
OK . . . so I'd like to create a shiny floor like a car showroom, could be black or a texture like marble, that bit doesn't matter so much. But I don't know where to start to make an object placed on the floor reflect in it.
Any help for this newbie very much appreciated.
Tim
Windows 7 - 64 Bit, i5-2410M core, 6Gb RAM, Poser Pro 2012 SR1
LukeA ( ) posted Mon, 17 August 2009 at 2:10 PM
You can play with the specular highlights, create a raytraced reflection, or an environment map.
LukeA
My latest novel
jonnybode ( ) posted Mon, 17 August 2009 at 2:14 PM
Hi!
Take a look at "Mapps" free Poser 5 materials:
www.renderosity.com/mod/freestuff/index.php
Use them and notice how they work, you can then learn to create your own or simply use thoose that Mapps so kindly offer.
Remember to enable reflections too.
Regards / Jonny
IsaoShi ( ) posted Mon, 17 August 2009 at 3:23 PM
Here's a simple black reflective floor you can try for starters.
The reflection correctly increases with decreasing camera angle to the surface, so when you are looking perpendicular to the surface there is much less reflection. The Edge_Blend colours are Inner (21,21,21) and Outer (177,177,177). If you want more reflection at a straight-on camera angle, lighten the Inner_Color slightly.
It has a slight bump to it, which you can remove if you want it perfectly smooth.
Shall I post the material file?
scarlock ( ) posted Mon, 17 August 2009 at 3:44 PM
IsaoShi - Would you please post a picture of the materials for your tile wall?  Thanks.
IsaoShi ( ) posted Mon, 17 August 2009 at 4:26 PM · edited Mon, 17 August 2009 at 4:29 PM
scarlock - of course, here ya go! Hehe - sorry, this is probably no good to anyone, but you did ask!
It's a parameter-controlled tile shader I'm still working on, in my rather dilatory way. As you can see it uses three separate tile nodes for colour, displacement and reflectivity, and it has the control parameters down the left hand side, easy to use in the Material Room, and also all set up to use with Parmatic.
I was going to give it as a freebie here in the forum when I was happy with it. I have not got it working correctly for all light conditions, so it's not really ready yet. But I can post the material file here if you want to have a play.
EDIT - it would not upload a JPG2000 file, so I replaced it with a normal JPG - less compression and worse quality, I'm afraid.
IsaoShi ( ) posted Mon, 17 August 2009 at 6:31 PM · edited Mon, 17 August 2009 at 6:31 PM
file_437298.txt
Here's the (compressed) material file for the tile shader. (Save it in your Materials Library folder somewhere and remove the .txt file extension).
I'm going to change the displacement, but I haven't had time. At the moment, it uses positive displacement for the tile surface, but this doesn't work well with things touching the surface - they get buried. So I'm going to change it to zero displacement for the tile surface, and negative displacement for the tile edges and mortar lines. (I should have done it that way in the first place).
In this version, I reduced the diffuse value to 0.8 (mainly for use with Poser 8 IDL), and I boosted the reflection falloff with camera angle (Fresnel effect), but I haven't had time to test it properly. The Edge_Blend node controls the Fresnel effect and the Diffuse/Reflected light balance.
The parameters are hopefully self-explanatory. I've found it best to load this shader on a Box or a One-Sided Square. I had problems using the GROUND, a Hi-Res square, and a Square. With the first two, the geometry interferes with the displacement. On the Square, the mapping is incorrect, and you have to remove backfacing polys in the render.
Happy tiling! I'll post an improved version when I've done it (Christmas, maybe!)
mapps ( ) posted Mon, 19 October 2009 at 11:27 AM
 I'v got a new set of mats coming out too with much better and faster reflective metals listed as car metals. Should be ready in the next few days :-)
TrekkieGrrrl ( ) posted Mon, 19 October 2009 at 6:08 PM
 Oooh now that is good news, Mapps! I've always loved your material collections ^_^
mapps ( ) posted Mon, 19 October 2009 at 8:07 PM
I am working on it right now. It will have many new mats and a bunch of fixes to the old mats to improve the look and render speed. Basicly making fixes based on what i ahve learned since the earlier ones were made.
RobynsVeil ( ) posted Tue, 20 October 2009 at 8:57 AM
The generosity of this community never ceases to amaze me. Thank you, IsaoShi and Mapps... looking forward to learning about reflections from BOTH of you!
Metaphor of Chooks
mapps ( ) posted Tue, 20 October 2009 at 10:10 AM
 You're very welcome, I hope to have the new and revised mats finished tonight as today is my 5th anniversary of posting freebies at rosity.
hborre ( ) posted Tue, 20 October 2009 at 1:45 PM
Online Now!
That is greatly appreciated.  And Happy Anniversary!
aeilkema ( ) posted Tue, 20 October 2009 at 4:01 PM
Go for Mapps materials for sure. I'm working on a video that needed a car with a reflective floor and I used Mapps materials for that, as you can see from the image. I just picked the metal I liked the most. I've been using his materials for a few years now and they're awesome.
@Mapps, congrats with the anniversary and thanks for the awesome materials! Looking forward to the renewed set.
Food for thought.....
mapps ( ) posted Tue, 20 October 2009 at 4:09 PM
Thanks, hard to believe it has been 5 years :-)
It is just a small updat/expansion though, containing 314 materials (so Far) :-) there is a new section of Vehicle metals and finishes too. I also purchased some cars and wanted to change the surface apperance so I made some new car mats :-)
DarkEdge ( ) posted Tue, 20 October 2009 at 6:20 PM
Could you please provide a linky to the metal materials?
Thanks and regards
mapps ( ) posted Tue, 20 October 2009 at 6:48 PM
Not quite finished them yet hope to hve them done tonight, tomorrow at the latests for sure :-) Up to 320 mats now :-)
TrekkieGrrrl ( ) posted Tue, 20 October 2009 at 7:21 PM
 Wow what an anniversary present ^_^ And congrats with the anniversary! How time files!
Latexluv ( ) posted Tue, 20 October 2009 at 7:22 PM
Really looking forward to the new collection!
Weapons of choice:
mapps ( ) posted Tue, 20 October 2009 at 7:37 PM
Gee now I am geeling preassured, they had best be very good or I'm apt to get lynched ... lol
Latexluv ( ) posted Wed, 21 October 2009 at 5:44 AM
crossing heart Promise, no lynching!
Weapons of choice:
TrekkieGrrrl ( ) posted Wed, 21 October 2009 at 6:19 AM
  Well.. we might lynch you if they're not here soon ;)
Seriously.. No lynching. Promise! Your OLD materials were awesome so a new pack will only be more awesome!
mapps ( ) posted Wed, 21 October 2009 at 6:58 AM
 lol It will be ready tonight ... unless I start tweaking some more of them :-)
hborre ( ) posted Wed, 21 October 2009 at 9:21 AM
Online Now!
Instead of lynching, how about a good old fashion beating?
mapps ( ) posted Wed, 21 October 2009 at 9:56 AM
 Whipping me doesn't make me go faster :-)
TrekkieGrrrl ( ) posted Wed, 21 October 2009 at 3:42 PM
 What if we threaten NOT to whip you?
mapps ( ) posted Wed, 21 October 2009 at 4:29 PM
LOL that might speed it up :-)
DarkEdge ( ) posted Wed, 21 October 2009 at 6:44 PM
How about a glass of wine then?
I'll do my 12 oz. curls and you have a glass of wine...I toast you! 😄
mapps ( ) posted Wed, 21 October 2009 at 10:46 PM
sorry to say I was stretech so thin tonight with a million things to do i didn't get to work on the PC at all and so did not get to finish them. I will try most hard to get them done tomorrow :-(
RobynsVeil ( ) posted Thu, 22 October 2009 at 3:37 AM
Please, I don't care what the other say, don't rush. I rushed a shader, introduced a kludge, didn't test in enough light settings and now I have to fix it... and realize that rushing it just isn't worth it.
Take your time... remember, Poser and shaders is fun, not a chore... :)
Metaphor of Chooks
mapps ( ) posted Thu, 22 October 2009 at 5:46 AM
 lol Well they are 99% done I just need to finish them and yes some have needed to be adjusted after doing test renders in different settings :-)
mapps ( ) posted Mon, 23 November 2009 at 6:34 PM
Attached Link: Materials
OK sorry for the huge delay but the new set of 327 materails has just been uploaded to the freesection :-) you can also grab them here now using the link :-)
Anthanasius ( ) posted Mon, 23 November 2009 at 6:59 PM
Testing ;)
Génération mobiles Le Forum / Le Site
hborre ( ) posted Mon, 23 November 2009 at 7:03 PM
Online Now!
Thanks.  Will look forward to giving them a spin.
Anthanasius ( ) posted Tue, 24 November 2009 at 3:08 AM
Hum ... If you accept critics, good or bad, it's a chance it's free i really dont pay for that :-)
mapps ( ) posted Tue, 24 November 2009 at 5:06 AM
Tips and suggestions are alway welcome :-)
Latexluv ( ) posted Tue, 24 November 2009 at 6:01 AM
Thanks so much!!!!
Weapons of choice:
mapps ( ) posted Tue, 24 November 2009 at 6:52 AM
 you are welcome :-)
Anthanasius ( ) posted Tue, 24 November 2009 at 7:57 AM
Quote - Tips and suggestions are alway welcome :-)
I've the think  you dont take attention to all the threads who many users talk about reflection !!!
Putting a reflect node to the reflect ... Is there no work behind ...
ThunderStone ( ) posted Tue, 24 November 2009 at 8:02 AM
Thanks! These can be used for any car model or is there a specific model you had in mind?
OS: Windows 11 64-bit
Poser: Poser 11.3 ...... Units: inches or meters depends on mood
Bryce: Bryce Pro 7.1.074
Image Editing: Corel Paintshop Pro
Renderer: Superfly, Firefly
9/11/2001: Never forget...
Smiles are contagious... Pass it on!
Today is the tomorrow you worried about yesterday
mapps ( ) posted Tue, 24 November 2009 at 9:52 AM
 There are generic paint that can be used on any car model. I have purchased many models here that are awesome but are 3DS or OBJ and are not painted when you take them into poser. These mats are my solution to that.
Yes the reflective one require a real world Environment and do not work with Backdrops. There are several 3d world environments available in my free section.
I only use 3D environments and these are Mats used by me for my work. So they are set up the way I use them. If you are using sphere reflection maps you should use your backdrop for the mat so the reflection matches the environment. Use a reflection value of about 0.4 for metal and for colour use a medium grey do dark grey. this will help prevent washing out the colour on the model.
When I purchase a model that has sphere maps the first thing I do is remove all of them and replace them with RayTaced reflections.
ThunderStone ( ) posted Tue, 24 November 2009 at 11:57 AM
Thanks for the tips, mapp... 😄
mapps ( ) posted Tue, 24 November 2009 at 12:12 PM
 No problemo :-)
