Thu, Feb 6, 4:35 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 06 4:35 pm)
Subject: poser 7 pro Runtime ?
nikogr ( ) posted Tue, 18 August 2009 at 5:35 AM · edited Wed, 24 July 2024 at 5:14 PM
I recently install poser 7 pro and now I am wonder: what about the runtime from my previous poser version. How can move 50Giga to poser Pro??  Must be something that I am missing here?  Can any one help me??
Thank you all.
Lucifer_The_Dark ( ) posted Tue, 18 August 2009 at 6:08 AM
Don't move anything!!!!!
Run Poser 7 Pro, on the Library pallet you'll see a blue folder with an arrow pointing upwards, double click on that, you should now see 2 Blue folders Poser Pro & Downloads.
At the bottom of the pallet you'll see a tick & a + click on the + & use the browse box that appears to find your previous runtime folder, hit the ok button once you've found it & it should add the runtime into Poser Pro.
After that you can use the up arrow folder item to go between the runtimes.
Windows 7 64Bit
Poser Pro 2010 SR1
hborre ( ) posted Tue, 18 August 2009 at 9:18 AM
In situations like this, it is best to use runtime folders from other versions as external runtimes.  Otherwise, you will need to reinstall all your content into your current program.  Keep in mind, extremely large content folders will slow down your app considerably.  Creating smaller external runtimes will ease the burden.
BTW, there is no beast called Poser 7 Pro; it is either Poser 7 or PoserPro.  Although they are similar in appearance, there are some added features in PoserPro not found in Poser 7.
nikogr ( ) posted Tue, 18 August 2009 at 10:40 AM
nikogr ( ) posted Tue, 18 August 2009 at 10:41 AM
Thank you so much. Is working fine and i didnt have to move any files.
Thank you !!!
