Tue, Nov 12, 8:48 PM CST
Subject: Changing standard Editing Tool - Help
Jules53757 ( ) posted Tue, 18 August 2009 at 3:45 AM · edited Sun, 10 November 2024 at 3:29 AM
Poser 6 and 7 started by default with the translate/ pull editing tool as active, Poser 8 starts with rotate as default. Is there a way to change this?
Ulli
deni67 ( ) posted Tue, 18 August 2009 at 8:18 AM
Set up your UI the way you want it then go to Edit/General preferences, click on the interface tab and under Launch Behaviour select Launch to previous state then go to the Document tab and under Launch Behaviour click on Launch to preferred state then click set preferred state and ok and your poser will open up just as it closed..
I don't actually think you need to do the first step on the interface tab but i do it just in case..lol
Jules53757 ( ) posted Tue, 18 August 2009 at 8:29 AM
That was my first try, sorry, doesnt work in P 8 and I didn't find any reference in the Poser.ini and the .xml files.
Ulli
Believable3D ( ) posted Tue, 18 August 2009 at 8:32 AM
Funny, I hadn't even noticed this particular issue before you mentioned it.
I really wish General Preferences gave greater control - e.g. have new lights come in with certain settings, new figures come in with IK on or off as I choose etc.
______________
deni67 ( ) posted Tue, 18 August 2009 at 8:33 AM
Sorry about that..
Jules53757 ( ) posted Tue, 18 August 2009 at 8:36 AM
No Problem in P 6/ P 7 it worked.
Ulli
bagginsbill ( ) posted Tue, 18 August 2009 at 10:47 AM
This is very annoying to me, but nobody ever mentioned it so I thought I was being picky.
I prefer the translate tool active, but remembering what I last used isn't bad. P8 doesn't do either. Tell SM! They think I'm peculiar and sometimes don't listen to my requests, since I clearly do not represent the average user. ;-)
http://support.smithmicro.com
JoePublic ( ) posted Tue, 18 August 2009 at 11:00 AM
Similar problem:
The memory dots also lost their "memory".
They always revert back to "UI" when I restart Poser even though I use "Pose" 99% of the time.
Even worse, after a while they stop working completely so I now have to save each new pose I create to the library immediately.
Jules53757 ( ) posted Tue, 18 August 2009 at 11:09 AM
I did it but when I think about my question about the possibility to get the Poser8Content.zip as a splitted archive and the answers, I don't expect any helpful answer.
Ulli
Jules53757 ( ) posted Tue, 25 August 2009 at 3:08 PM
Additional strange behaviour, when starting Poser the rotate is active, switching to the material room and back, the translate pull is active.
Ulli
ajsavill ( ) posted Wed, 26 August 2009 at 10:33 AM
 I've also deleted figures and had the control switch to rotate afterwards. Someone at SM is clearly a big rotation fan...
momodot ( ) posted Wed, 26 August 2009 at 11:54 AM
This has been making bananas but I figured I was alone in it.
