it appears as though the bump map has not been assigned to the top one for some reason,
Theres a couple of thigns you could try,
Open up the function editor and see if anythign odd has happened, if theres nothign there, assign a texture node with the bump map and try that way.
Or just reassign it in the simple material editor.
Great looking amps though, you really nailed the "leather" material :)
Rich
http://blog.richard-potter.co.uk
perhaps you could try assigning a completely different material (for example like rocks or something) then try and reasign the correct material (assuming you havent tried this already!)
Rich
can you post some screenshots of the bump page in the editor? someone will probably be able to come up with something.
just a thought.... whats the scale of the bump material on the top one compared to that of the bottom one?
Rich
Ben
